fuel system
Old Feb 10, 2015 | 06:34 PM
1966mustang's Avatar
1966mustang
fuel system
long question made short......po190/po191 changed fuel filter, mud out, cleared codes, run good, stalled out, checked filter has clear gas, replaced fuel pump, has power to fuel pump til plugged into fuel pump, please help!!
Old Feb 11, 2015 | 09:28 AM
canstacker's Avatar
canstacker
Have you checked the fuel pump driver, mounted on cross member behind spare tire?
Old Feb 11, 2015 | 09:49 AM
1966mustang
Not sure how to do that can you please tell me
Old Feb 11, 2015 | 02:28 PM
1saxman's Avatar
1saxman
What truck do you have? Later models have a fuel pump driver module as stated above. First, lower the spare tire and look at the device. If you see any powdery corrosion on the aluminum lower plate, you may as well get a new one and install it. Search this forum for it and you will see some excellent pictures posted of bad ones.
Old Feb 12, 2015 | 08:07 AM
1966mustang
Thank you all that was the problem. FYI the pump was original...2003, truck is 2004. lots of gas went thru that baby. Thanks again for your help. My Ford is up and running again.
Connecticut Calvin
May 9, 2019 09:13 AM
darrin1755
Feb 6, 2011 11:47 AM
AFoster1025
Oct 25, 2010 05:48 PM
andrew1
1997 - 2003 F150
Oct 12, 2006 02:47 PM
shawn
Jan 15, 2004 12:34 AM
