Missing jack & tools
Old Feb 10, 2015 | 08:19 AM
Silverlake's Avatar
Silverlake
I'm missing the under-hood jack and tools on my 2000 F250
I've been searching online but can't seem to find an exact match in the description.
Can anyone tell me if this set would be identical?
http://www.ebay.com/itm/FORD-E250-E350-EXTENDED-ECONOLINE-VAN-JACK-AND-SPARE-WHEEL-TOOLS-/360946486804?hash=item540a164e14&item=360946486804&pt=Motors_Automotive_Tools&vxp=mtr
It's from a 250 Econoline.
Any other links to the OEM bits would be appreciated.
Yeah, missing the spare as well
Old Feb 10, 2015 | 10:22 AM
JOHN2001's Avatar
JOHN2001
On an SD the lug nut wrench is the handle for the Jack. It has a square hole in the center of it. Not saying that's not going to do the trick but that's the difference.
Go to a junk yard
Old Feb 10, 2015 | 11:22 AM
tjc transport's Avatar
tjc transport
i ain't rite
the jack handle is mounted on the top of the radiator.
the jack should be on the passenger side rear of the cab, not under the hood.
this is the proper one for your pickup:
http://www.ebay.com/itm/02-Ford-F-25...-/291377464121
Old Feb 10, 2015 | 11:28 AM
AllaboutMPG's Avatar
AllaboutMPG
I think this is what your looking for.
02 Ford F 250 Super Duty Factory Jack Lug Wrench Handles | eBay
edit.........Tom beat me to it
Old Feb 10, 2015 | 01:38 PM
TinyWonder's Avatar
TinyWonder
X 2 on the junk/wrecking yard.
Pennies on the dollar for factory parts that hardly ever get used.
For that matter... just get a heavy duty hydraulic jack and be sure to have some basic tools handy too.
Old Feb 10, 2015 | 01:50 PM
tjc transport
i ain't rite
while a hydraulic jack is just as good if not better than the stock jack, without the stock tools the only way to get the spare tire down from under the truck is with a cutting torch.
you need the jack handle and lug wrench to operate the spare tire winch. provided you still have the key in the glove box.
Old Feb 10, 2015 | 02:41 PM
Walleye Hunter's Avatar
Walleye Hunter
Two things I would check on that van jack kit:
1) Capacity of the jack. Is it strong enough to lift your pick up when loaded?
2) I don't know about your truck but the studs on mine stick out pretty far past the nuts and the lug wrench needs to be deep enough to handle that.
Old Feb 10, 2015 | 07:20 PM
Silverlake's Avatar
Silverlake
Thanks for all the replies.
I went with the one in Tom's post. I wanted it to be "stock" so this is just the ticket - just couldn't find that "specific" one for some reason - thanks Tom .
As for the less expensive junkyard recommendations, my junkyard days are over (aaah - fond memories of my yoot).
One of the troubles with living in a big city and 15 minutes from the border - everything of value has been picked clean by the second day from arrival - nothing left but bones. It will also cost a half a Saturday which is worth about 250 bucks to me .
So, ninety-three bucks is a deal (includes shipping) .
All I have to do is open the package and insert the bits into the rig.
Thanks again all.
Jim
CottonTexas
21
Aug 3, 2018 10:15 PM
51dueller
Oct 15, 2013 08:28 AM
SC_Hoaty
Oct 29, 2012 04:01 PM
tbm3fan
16
Oct 25, 2007 05:54 AM
Rivdog
Sep 12, 2003 11:43 AM
