Dash lights stay on
Old 02-09-2015, 09:57 PM
cdmm151's Avatar
cdmm151
cdmm151 is offline
Dash lights stay on
Has anybody found a fix for the dash lights that stay on? I know of 2 trucks that dash lights stay on all the time. Dome lights are not on so it should be the doors causing it.
Old 02-10-2015, 09:42 AM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
cdmm151 - Has anybody found a fix for the dash lights that stay on? I know of 2 trucks that dash lights stay on all the time. Dome lights are not on so it should be the doors causing it.
There are a numer of issues that can/cause the dash lights to cycle-on/off. Some of self-inflicted (e.g. leaving the key in the ignition), others are the result of faulty switches and/or modules, and still others have yet to be resolved (may be a network(ing) software issue?????).
So ... Describe you problem(s). And while you're at it .....
Eenie meenie chilli beanie,
the spirits are about to speak!
And the year, model, cab, trim, engine, wheelbase, _x4 drive, etc. of your F-150 is ?????
HINT/TIP: Put your vehicle information in your sig' -OR- provide it in your posting(s).
*Telepathic or Karnak we're not.
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old 02-11-2015, 07:47 AM
cdmm151's Avatar
cdmm151
cdmm151 is offline
This is happening o n two diffent trucks. One is a 2011 F150 crew,FX4 with a 5.0 and the other is a 2012 F150 crew, FX4 with 5.0. Both do not have nav.
Old 02-21-2015, 11:39 AM
Big Whitey's Avatar
Big Whitey
Big Whitey is offline
Lights on
I have a 2012 raptor that had the backlighting came back on after the key off time out would shut it all off. Then by the time I was in the house, the cluster would come back on and run the battery dead. The dealer was all over the door switches, but it ended up being in the shift module in the console. If you leave your rig in neutral the dash lights stay on as a safety measure so you will notice it and check things. Thats what he told me anyway. Hope it helps.
Old 02-21-2015, 09:33 PM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
cdmm151 - This is happening o n two diffent trucks. One is a 2011 F150 crew,FX4 with a 5.0 and the other is a 2012 F150 crew, FX4 with 5.0. Both do not have nav.
-IF- you're not leaving the key in the ignition after turning the vehicle -off-, exiting, and closing the door then you will need to take the vehicle(s) to the dealership to have the situation diagnosed.
Otherwise, take the key out of the ignition when you exit the vehicle.
Possible issues (known to date) ...
  • malfunctioning door switch(es).
  • central timer module (component of BMS) turning on by itself intermittently.
  • back-up camera harness short.
  • faulty ignition switch.
  • faulty shift lever micro-switch.
  • software calibration issue with the BMS.
  • faulty BCM.
-click- the pic'
Goth 150
Old 02-22-2015, 11:17 AM
conger's Avatar
conger
conger is offline
Welcome to the club. Search other forums for this long unsolved problem. There are no clear fixes from Ford to date. In fact they are remaining tight lipped about even acknowledging a problem.
Best guess is a software issue where the instrument display doesn't process a power down command.
My 2013 will not have enough power to start after 5 days of sitting. And it's in a heated garage.
Old 09-04-2016, 01:07 PM
Fordtruckking1987's Avatar
Fordtruckking1987
Fordtruckking1987 is offline
I had the same problem. I found on another forum that it's because of a shift interlock switch that goes bad in the shifter center console. There is a guy selling them on eBay. Much cheaper than replacing the entire center console! It fixed my problem in 30 minutes.
www.ebay.com/itm/162075698977?_mwBanner=1
Old 10-13-2016, 12:41 PM
Fordtruckking1987
Had a neighbor with the same problem in his 2011. Went to buy the switch but looks like it has been relisted. Here is the new link. Cheers.
2011 2014 F150 Dash Light Staying on Fix Brand New Switch Free Shipping | eBay
Old 01-17-2017, 09:47 PM
Fordtruckking1987
Listing was updated so that now it includes all the supplies to make the repair and full color instructions as well. Hope this helps.
http://www.ebay.com/itm/162362431709?ssPageName=STRK:MESELX:IT&_trksid=p39 84.m1586.l2649'
Old 01-18-2019, 02:52 AM
gzukoff's Avatar
gzukoff
gzukoff is offline
Here is a new listing with a much lower price.
https://www.ebay.com/itm/292902064134
Old 06-04-2019, 07:59 PM
skoeper's Avatar
skoeper
skoeper is offline
2013 Explorer dash lights stay on after turning off
My -13 Explorer dash lights stayed on today when I stopped for gas. They looked weird (clock wise lines where the speedometer should show). Filled up with gas, then got in and it wouldn't start. After another attempt, it did start. When I got home, I turned it off and the lights again stayed on. Both on the dashboard and on the screen (where the back up camera shows). Just blank lights on the screen. Eventually it turned off. Restarted the truck and it started fine. But when turning off, again.....the lights are different. I'm afraid of being stranded somewhere, do I need to have this looked at?
Old 07-14-2020, 08:25 PM
gzukoff's Avatar
gzukoff
gzukoff is offline
Here are all the listings, the item numbers and URLs keep changing.
https://www.ebay.com/sch/newyorkbuyer/m.html
troverman
1999 to 2016 Super Duty
48
08-21-2016 10:32 PM
say when
2009 - 2014 F150
18
12-19-2009 05:34 AM
frankf150
1997 - 2003 F150
07-24-2006 01:32 PM
Quick Reply: Dash lights stay on
