2001 ranger engine swap
Old Feb 9, 2015 | 08:29 PM
brett.topo's Avatar
brett.topo
Hi, im new to the forums here and have some questions. I have a 2001 ford ranger 2.5 and a standard 5 speed. Its been knocking for a while now and recently its made a much lower tone knock, im thinking I may have thrown a bearing. If someone has had a problem lole thus how did you fix it? Also I am wondering what other engines I can use, besides the 2.5. Thanks
Old Feb 10, 2015 | 08:45 AM
exranger06's Avatar
exranger06
The only way to fix that is replace the bearings and/or do a full rebuild, or install a new/used engine. The only engines that will bolt right in and work is another 2.5 or an older (1997 or older) 2.3. The older 2.3s actually are the exact same engine as the 2.5, just with a shorter stroke. The newer 2.3s (2001+) are entirely different and will not be a bolt-in replacement. They have a different bell housing bolt pattern, among other differences. Any V6 engine will also have a different bellhousing pattern. And the 5 speed transmission you have has a non-removable bellhousing, so swapping to any other engine will also mean swapping to a different transmission.
Old Feb 10, 2015 | 10:48 AM
brett.topo's Avatar
brett.topo
Thank you exranger that actually helps out alot. With that being said, would ypu prefer the 2.3 or the 2.5? Im running 31inch mud claws.
Old Feb 10, 2015 | 02:45 PM
exranger06's Avatar
exranger06
Well like I said they're basically the same. The 2.5 has slightly more power and torque, and it's what your truck originally had, so I would prefer that. If you want more power for bigger tires, I would re-gear the rear axle and not bother trying to upgrade the engine.
meck1
Dec 28, 2009 05:29 PM
Trafficflow
Aug 10, 2009 09:21 PM
meck1
Jul 30, 2007 12:27 AM
captaincanuck
Oct 14, 2004 07:53 PM
amp17757
Dec 6, 2003 10:29 AM
