"97" 7.3 will not start????
Old Feb 10, 2015 | 12:06 PM
cowmilker08's Avatar
cowmilker08
15-20 psi to start, 60-70 once idling.
Old Feb 10, 2015 | 12:32 PM
dumptruck denny's Avatar
dumptruck denny
and if i do not have that where do i go then
Old Feb 10, 2015 | 12:35 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
If you don't have that then it's time to figure out why not
Old Feb 10, 2015 | 01:18 PM
dumptruck denny
just went i tried the pressure at the schreader had 15 lbs while cranking
Old Feb 10, 2015 | 02:35 PM
MOOSE_MACHINE
That should suffice. Follow the next thing on that chart
Old Feb 10, 2015 | 04:57 PM
dumptruck denny
it says check ipr its new pcm is new icp is new what do i do, thanks alot any how
Old Feb 10, 2015 | 06:59 PM
fordman67's Avatar
fordman67
Check system voltage while cranking.it MUST be over 10.5 volts..it won't run otherwise.EVEN if it sounds like it is cranking fine.
Then...pull idm and check it for water.its the module mounted on driver fender that you can see the whole module.
Old Feb 11, 2015 | 09:35 AM
farmert's Avatar
farmert
Originally Posted by oldbird1965
Great, if you have e fuel that's one mod you don't have to do. Much better then stock mechanical fuel pump.
Yes, but the next question is did the P.O. install true electric fuel, or just a band aid inline fuel pump.
If you still have the fuel bowl, you don' have true electric fuel. The mechanical pump is a 2 stage pump, low pressure to the filter,and back to the pump for high pressure to the injectors. The inline low pressure pump will fill the fuel bowl, but will not run the high pressure to the injectors.
Old Feb 11, 2015 | 10:06 AM
oldbird1965's Avatar
oldbird1965
Thanks for the correction Tom, I thought about my answer after and realized he was talking about a 'fuel bowl' filling up. Defiantly something to check out.
Old Feb 11, 2015 | 10:36 AM
dumptruck denny
thanks guys, yes i am sorry not to explain my self yesterday i wosnt sure whats what on these diesel trucks learning as i go. yes it is a extra in line fuel pump do not know anything about it, but he said he put one in.
Old Feb 11, 2015 | 10:53 AM
dumptruck denny
so what should i do take the in line pump off
Old Feb 11, 2015 | 10:58 AM
dumptruck denny
p.o. said he put every thing new in rear fuel tank because front was leaking so he bypassed and i think removed it,i havnt really looked.thanks denny
Old Feb 11, 2015 | 11:03 AM
  #28
farmert's Avatar
farmert
My gut is telling me the mechanical pump died, and the P.O. installed an electric pump thinking this would give it fuel. If you remove the electric pump and check the fuel pressure while cranking and don't get 20 lbs, the mechanical pump has given up the ghost, and needs replaced. It will run on either, so this says it is not getting fuel to the injectors. The question is why.
Old Feb 11, 2015 | 11:09 AM
  #29
dumptruck denny
if i would put diesel in a can and hook in the line up by the fuel pump by motor would that start it,if the back pumps not working.
Old Feb 11, 2015 | 11:59 AM
  #30
cowmilker08
There are no pumps in the tanks on these trucks. In a stock set-up the pump sucks fuel up to the engine. You should be able to disconnect the in-line electric pump, stick the hose in a can and see if it builds fuel pressure.
