How the H*LL??
Old Feb 7, 2015 | 05:52 PM
bleeds blue's Avatar
bleeds blue
How the H*LL??
Ok, most of the way done with my FRX install. I need to grind down the "Baby Butt" in order for the last fitting to be installed. What in the world are you guys using to grind that cast iron with?
I've tried both of my angle grinders, with the most worn down disk I can find. None of the come even close to fitting in there.
Also, how much metal am I removing? I dont want to go all the way through the pipe as they aren't leaking at this point.
BTW, I love the free hood latch tattoo you get on your stomach during this install!
Old Feb 7, 2015 | 05:55 PM
F350-6's Avatar
F350-6
I don't recall having to grind the baby's but when installing a FRX.
If you've got to, the only way I can see it being done is mark it in place, then remove it to grind it down.
The good news is, removing the baby's but isn't too hard.
(after the turbo is out of the way.) Putting it back in sucks though.
Old Feb 7, 2015 | 05:58 PM
bleeds blue
Dont want sucks! Haha. The piece that goes into the head can thread in without it. But the hose will not screw onto it without grinding. The instructions say on E99's you have to grind it. I've read on here how other E99 owners had too as well. I just need to know what kind of tool they are using...... She's sitting in the road with the hood up right now.
But, on the good side. My back is getting a much needed rest!
Old Feb 7, 2015 | 06:04 PM
bleeds blue
For arguments sake. Lets say I dont have a shop with air tools....
Old Feb 7, 2015 | 06:15 PM
David7.3's Avatar
David7.3
Do you have an air compressor? a 45 dollar die grinder with a set of carbide bit cutters will more than do the job.
Old Feb 7, 2015 | 06:16 PM
David7.3's Avatar
David7.3
oh yea, throw a fender cover over the latch prevents the tattoo.
Old Feb 7, 2015 | 06:20 PM
AllaboutMPG's Avatar
AllaboutMPG
an old piece of carpet or bath mat will soften the poking in the belly as well
Old Feb 7, 2015 | 07:20 PM
whitetmw's Avatar
whitetmw
Dremel Tool
Old Feb 7, 2015 | 08:00 PM
bleeds blue
So I used this as an excuse to buy a dremel. I used the little tootsie roll looking sand disk in 60 grit. After sanding and test fitting too many times. I forgot to put the plug back in the head so I'm sure I filled it full of metal shavings. I turned the fuel pump on to flush it out. Sent diesel fuel everywhere but the fitting still didnt fit. I didnt feel like starting the truck on fire so I'm done for the night..... Hopefully tomorrow when the sun is back up and the fuel had dried up I can finish it.
For those who havent done this on an E99, it isnt a 1 hour job, or a three beer job! You need to drive it afterwards apparently. Hopefully I can get it done tomorrow.
Old Feb 7, 2015 | 09:44 PM
bigb56's Avatar
bigb56
maybe one of those diamond impregnated grinder discs for grinding on concrete?
Old Feb 8, 2015 | 07:34 AM
Tugly's Avatar
Tugly
Cutting disc, without using too much pressure. Is there a file-like drum? Sanding is too slow. Hack saw disk?
Old Feb 8, 2015 | 08:04 AM
jhl3's Avatar
jhl3
A rotary file is what I used and it was a pain. That added an hour to the install.
Old Feb 9, 2015 | 12:41 PM
bleeds blue
Cutting disk on a dremel. I could see someone cutting all the way through the pipe on accident with that though!!!
It's all done and running. The only difference I can tell is starting. I swear it is cranking over while starting 10 times faster than it did before. Am I imagining things, or have other people experienced this?
Batgeek
21
Jun 23, 2019 01:04 PM
fordman19762003
2015 - 2020 F150
Nov 12, 2018 09:37 PM
BigBlueCat
Sep 16, 2014 01:25 PM
aklim
Apr 9, 2006 02:42 AM
Toreador_Diesel
Mar 23, 2006 07:10 PM
