excursion wheel spacers or...
Old Feb 8, 2015 | 07:48 AM
JuanHuevos's Avatar
JuanHuevos
I made the exact same mistake back in November. I got some 2015 F-250 wheels and tires for cheap and thought they would work just fine. Nope, so I got the 2" spacers from WheelAdapter.com and all is now good in my neighborhood. Here is a post chronicling my adventure.
https://www.ford-trucks.com/forums/9...ty-rims-6.html
Don't try and be cheap and cut corners on these spacers. You won't like the price of them but having a wheel come off on the highway would ruin your day.
Old Feb 8, 2015 | 11:00 AM
Apocalypse's Avatar
Apocalypse
I "went cheap" on the spacers and had no issues and am glad I did. The quality of what I received was just as good IMO as Freds although in Aluminum but at half the cost they were great for almost 2 years. I however have a 2wd 5.4, so the diesel might be a concern because of the weight but personally I loved mine.
http://www.ebay.com/itm/OEM-HUB-CENTRIC-PNP-50MM-WHEEL-ADAPTERS-SPACER-FORD-8X165-CB-125-5MM-9-16-UNF-/140909841661?pt=Motors_Car_Truck_Parts_Accessories&hash=item20cee18cfd
Old Feb 8, 2015 | 12:25 PM
hexbolt's Avatar
hexbolt
Trailering
whoops, wrong thread
Old Feb 8, 2015 | 12:29 PM
hexbolt's Avatar
hexbolt
Trailering
Yeah I'm getting rubbing on the frame in the front. only when i crank the wheel all the way. This is pretty much the neighborhood, school drop up vehicle. I work from home and avoid highways mostly so I'm not too concerned right now. just avoid uturns and order them asap. I will get the hub centric spacers for sure. as for the back. I thought the hub stuck out quite a bit but under daylight I realized that it does taper a bit so that idea is gone.
As for my profile. I purposely kept it blank, but i see your point. I'll update it.
WERNER1
15
Jun 3, 2019 04:20 PM
dethpulse
Aug 15, 2018 07:23 PM
Pele
Sep 20, 2017 09:22 PM
ufvj217
Aug 23, 2017 08:11 AM
QwkTrip
Aug 8, 2009 12:35 PM
