Sluggish off line when warm
Old Feb 7, 2015 | 03:18 PM
Bite N Hold's Avatar
Bite N Hold
So after I've been driving for a while and stop at a light or drive thru, I will give it throttle and it seems like it wants to stall. Almost like the turbo isn't spooling and then does and all is good again. Is this a sticking turbo bearing or something else? I am not very familiar with this motor(although I have been doing a ton of searching on here) as I just got it about two weeks ago.
I should mention that I am getting the 404 and 405 codes so not sure if that could be involved with the egr?
Old Feb 7, 2015 | 08:53 PM
RideDiesel88's Avatar
RideDiesel88
Well your turbo isn't going to spool sittin in the drive thru. Never really heard of a 6liter stalling from bad egr. those codes are for range/performance and low circuit for egr. Start by cleaning and making sure the egr valve functions properly. You really need to invest in some sort of gauge system. Turbo duty cycle % and boost are two main things to always monitor to rule out your turbo
Old Feb 8, 2015 | 05:43 AM
Bite N Hold
I realize the turbo doesn't spool at idle. Normally when you give it throttle, the boost immediately builds and you accelerate. When this happens, I give throttle and it kind of falls on its face for a few seconds and then takes off building boost. I have a Torque Pro set up and an Edge Evolution, but am not seeing "turbo duty cycle %" in the settings??? I can see when there is boost pressure and when there isn't.
Old Feb 8, 2015 | 08:34 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Replace the EGR valve.
Josh
Old Feb 8, 2015 | 08:48 AM
Bite N Hold
Josh
So you think that is the culprit? Can a bad egr cause this?
Old Feb 8, 2015 | 09:20 AM
Bullitt390's Avatar
Bullitt390
You have 2 codes showing the internal circuits within the EGR Valve are bad.
If the valve is partially stuck open you'll lose boost and won't spool as fast.
Josh
Old Feb 8, 2015 | 09:25 AM
Bite N Hold
Josh so you are saying it is bad. It is beyond pulling and cleaning or is it not worth it to do?
Old Feb 8, 2015 | 09:26 AM
Bullitt390's Avatar
Bullitt390
It's the electrical side of the valve that's bad.
Josh
Old Feb 8, 2015 | 09:33 AM
Bite N Hold
Josh
Very good. I'm ordering a new one now!
Old Feb 21, 2015 | 09:35 AM
Bite N Hold
Bulitt- Put new egr in and issue is gone!!!! Thanks. This forum is great!!!!
Captn B
Oct 24, 2014 01:51 PM
lakewood
Aug 10, 2010 05:30 PM
05whitef250
Jun 8, 2010 10:47 PM
a-rod
May 30, 2007 10:28 PM
