Horn relay
Old Feb 8, 2015 | 07:32 PM
19711969's Avatar
19711969
Originally Posted by Tedster9
That's OK, this has been wired "backwards" since I bought it 20 years ago. Gotta get on that.
Haha!! when it comes to putting off things I'm the champion.
Old Feb 9, 2015 | 09:24 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Changing Wiring
I'm with the old hands on this one.
If F*rd could have left something out, or simplified it more, then they would have. True, there are some improvements to be made, but skipping components isn't one of them. You don't want horn current going into the cab and back out. Extra big wires are heavy, carry some risk and work poorly.
Some wires might be replaced with one size larger. (And, there is the recommended headlight-relay modification, 3G upgrade, etc.)
If you are tempted to start removing things, learn more.
Wires are partly sized to protect the 'load' on the circuit they create. Big wire = more current = more heat = shorter life = dead devices on Saturday night. Don't risk your romantic opportunities. Valentine's doth approach.
If anyone wants to get real technical on this, let's take it offline, and do a well-reviewed job of it.
Kevin
Old Feb 10, 2015 | 02:56 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by orich
It should not take you any longer to switch those wires around way less then it takes to take a whiz. Unless you been drinking a lot of coffee or beer.
Orich
This reminds me of, I think it was Jerry Lewis, doing a character with crossed eyes and buck teeth..........
Feb 7, 2015 12:38 PM
bill2298
Jan 13, 2015 07:51 PM
Dirt1dobber
Sep 23, 2006 03:12 PM
55forder
May 1, 2006 11:59 PM
1972ford_f-100
Apr 2, 2006 04:45 PM
