460 Id
Old Jul 22, 2003 | 12:13 PM
daniel's Avatar
daniel
460 Id
Hello,
Can anybody help me with identifying a motor I've got? I bought a '49 ****** Panel van and this engine was in it. The front of the block on the drivers side is stamped "460". Only it's backwards,(like in a mirror). Where else can I look? Thanks. I'm new around here and am really enjoying this forum.
Dan
Old Jul 22, 2003 | 12:48 PM
Mil1ion's Avatar
Mil1ion
460 Id
Look for casting part numbers:
1)On the intake manifold
2) On the heads (just below valve cover around the spark plugs)
3) On the block just up in behind the starter on the side of the block.
Old Jul 22, 2003 | 06:54 PM
daniel's Avatar
daniel
460 Id
OK, here's what I found: the heads are: C8VE-A
the block over the starter is: C9VE-B
the tag under the coil is: 460 69 3
9A (ford logo) K866-T
The valve cover sticker has a number also: C8AE-9C485-D
these valve covers also have 7 bolts. Thanks.
Dan
Old Jul 23, 2003 | 08:04 PM
Big F250's Avatar
Big F250
460 Id
Looks like a 69 429 or 460 by the casting numbers. Good engine.
Old Jul 23, 2003 | 09:31 PM
Mil1ion's Avatar
Mil1ion
460 Id
866 is the 460 code thus a 69 ,460 from a Lincoln.
Old Jul 24, 2003 | 06:24 AM
daniel's Avatar
daniel
460 Id
Thanks guys,
Using Dennis's links I had the year and veh. it came out in, but I didn't know for sure if it was a 460 or 429. I'll try to ID the tranny when I get home tonight. I read (Dennis's links again!) that the C6 has an intregal bell housing, mine does, so I'm thinkin' that's what it is.
Thanks for the excellent info. on your links Dennis. excellent material there.
Dan
RL&C
Aug 31, 2014 11:21 PM
jamusfam
Apr 25, 2014 10:38 PM
davewest
Oct 6, 2010 10:51 AM
dangerrnager33
Jan 13, 2004 07:52 PM
1987blueovalcrazy
Aug 28, 2003 08:05 PM
