Engine skips a beat
Old 02-06-2015, 09:51 PM
Scruffy's Avatar
Scruffy
Scruffy is offline
Engine skips a beat
Hi guys,
Truck is a 2001 F-250 7.3 with 436,000 miles on it, had it since new. The only thing done to the engine was glow plugs last year.
I am starting to have this issue and I know my description is very vague but.... I will be driving along steady RPM, and the engine will just skip a beat. Sounds like it stops firing for just a second the will resume running. The truck doesn't buck or jerk, lights and radio stay on. Seems like it is happening a little more frequent like 2 or 3 times a week and I drive 100 miles a day. Again I know it could be a million things but does these symptoms sound familiar to anyone?
Old 02-06-2015, 09:53 PM
TKegs763's Avatar
TKegs763
TKegs763 is offline
Sounds like a CPS to me.
Old 02-06-2015, 10:06 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
I had that symptom and it gradually got worse. I cleaned grounds and fuses and swapped relays, could be a host of electric doodobs. In my case it turned out to be the ignition switch. Mounts on the underside of the steering shaft, not where the key goes. Here's a pic of it below.
Old 02-06-2015, 10:12 PM
Scruffy's Avatar
Scruffy
Scruffy is offline
TKegs,
I forgot about that. But now that you mentioned it I had a CPS go out and I think it was kinda the same symptoms. Soon after they had a recall on them and haven't had the issue since. That was around 2005 so it has been in there for 10 yrs.....
Easy fix, I'll try it and see. Thanks
Old 02-06-2015, 10:15 PM
Scruffy's Avatar
Scruffy
Scruffy is offline
David,
I'll keep that in mind as well.
Old 02-06-2015, 10:17 PM
TKegs763's Avatar
TKegs763
TKegs763 is offline
Originally Posted by Scruffy
TKegs,
No problem! Hopefully that's all it is. Make sure you only replace it with one from Ford or International.
Old 02-06-2015, 10:21 PM
Scruffy's Avatar
Scruffy
Scruffy is offline
Oh ya for sure on that. I am done with the box store "life time warranty" junk. There is a reason they give you that.....
F250_
29
11-05-2010 09:06 PM
HighOctane
10-02-2008 07:17 PM
GregN
15
02-24-2008 01:30 PM
farmdad
02-08-2008 10:52 PM
Tim B
General Diesel Discussion
10-23-2007 03:46 PM
Quick Reply: Engine skips a beat
