Sponsored by: Real Truck
2011-2015 Common Issues?
Old Feb 6, 2015 | 02:42 PM
obwielnls's Avatar
obwielnls
HI guys.. I'm looking to buy a 2011-2015 250 or 350 4wd with the Diesel engine and Crew cab.. I've found a 2011 that seems to run and drive well and I'm close enough to want to do more research.
Any common failures on these I should look for?
This one is loaded up fully , nav, heated/cooled seats, the works.
Thanks in advance guys.
Bill
Old Feb 6, 2015 | 04:26 PM
17 Oaks's Avatar
17 Oaks
Bought my '11 new, it was a Lariat F 350 dually, put 40k on here over 4 years and NEVER took it in for a warranty issue. Great truck.
Old Feb 6, 2015 | 06:14 PM
obwielnls's Avatar
obwielnls
What's this I'm reading about dropping exhaust valves?
And some sensor that leaves you on the side of the road?
Bill
Old Feb 7, 2015 | 02:49 AM
Unrealo4's Avatar
Unrealo4
Some of the 2011's got potentially bad exhaust valves. Basically they are a two piece valve that can come apart and wreak havoc on your engine. It's still a rare occurrence, like maybe 2%. The "Stop Safely Now" was a failed egt sensor. It would cause the truck to basically not drive. That is now fixed with the current recall flash. Buy a 2012+ and don't worry!
Old Feb 7, 2015 | 08:35 AM
fordman19762003's Avatar
fordman19762003
also heard some issues with radiators cracking. For the most part the 6.7's have been really good engines and I wouldn't be afraid to buy one if I needed a diesel.
Old Feb 7, 2015 | 09:18 AM
Unrealo4's Avatar
Unrealo4
Yes the radiators fail pretty easy too. I know mishimoto makes a replacement that's fully aluminum. It costs like $250 more then a oem replacement. But worth the extra money it will be the last one you install. These have been failing since 2008. They are the same as the 6.4 radiators.
Old Feb 7, 2015 | 09:25 AM
jbullfrog's Avatar
jbullfrog
The heater plenium is known to have the doors wedge and break causing the vents to not change from low to vent to defrost.
Old Feb 7, 2015 | 10:35 AM
Thomas D.'s Avatar
Thomas D.
Ok, call me petty, but my biggest gripe with my 2011 SD is not anything mechanical. It's the fact that engineers never seem to notice the basic flaws of their design. I'm talking about the windshield wiper pockets where the hood meets the windshield. My SD doesn't fit in my garage and those ?/!%$#@ plastic pockets are constantly packed with ice from the window defrost. I've had to readjust the wipers further up the windshield to keep the wipers from being constantly frozen to the cowl area. I saw these Ford SD prototypes up here in the middle of February running the Haul Road prior to their release in late 2010. And no one caught this issue. Sorry, love the truck, hate the lack of common sense details flaws in todays technology. It always works on paper....... Oh, and the fact that a screw driver and ball peen hammer pop the door lock out in 1 second. (This cost me $1,500 and I hadn't had the truck 1 week yet)
Mark Thompson
6.4L Power Stroke Diesel
Feb 26, 2024 02:04 PM
scottjima
6.7L Power Stroke Diesel
Aug 2, 2018 04:34 PM
turbinefix
Jan 14, 2016 08:41 PM
Amelio
17
Apr 13, 2015 01:43 PM
running bear
Nov 21, 2010 05:45 PM
