Lacking Power
Old Feb 6, 2015 | 10:27 AM
yasky69's Avatar
yasky69
Lacking Power
Purchased a 2007 with 114K about 3 months ago, Always runs like a bat out of hell. I noticed today my acceleration wasn't up to its normal routine. Definetly lacking its normal power
Outside Air Temp has been very cold today is 9 degrees
Oil / Filters Changed 1000 miles ago
EOT vs ECT is only a 4 degree difference at operating temperature
Turbo was boosting only to 20 psi, I think usually it goes a lot higher. My gut is telling me its just these cold temps but I want to be sure I'm not missing anything.
any thoughts?
Old Feb 6, 2015 | 10:39 AM
Iaff113's Avatar
Iaff113
Check the Cac boots to the turbo to make sure they are not leaking or torn
Old Feb 6, 2015 | 10:40 AM
RideDiesel88's Avatar
RideDiesel88
Pull your egr valve. Check ficm voltage. Any smoke out exhaust?
Old Feb 6, 2015 | 11:45 AM
yasky69's Avatar
yasky69
FICM is 48.5 volts
No smoke at all
Forgot about the EGR, I'll pull it and check.
I'll also check the CAC boots
Old Feb 6, 2015 | 07:44 PM
Lou Braun's Avatar
Lou Braun
At 9 deg F there is a very good chance that your fuel has partially gelled and the primary fuel filter is restricted.
I ran into the same problem this morning when it was -15 deg. The fuel had plenty of power service anti-gel in it, but it still jelled up enough to affect power.
The best preventive measure is to get fuel from a place that *really* has the correct winter grade and then add some additional anti-gel to it. A bottle of 911 is always handy to have.
I hate diesel jelly.
Lou Braun
1fastroadking
May 25, 2010 06:04 PM
gearloose1
Apr 3, 2010 08:36 PM
Baddfx4
Jan 23, 2010 09:04 PM
ford4x4956
Apr 7, 2009 07:15 PM
