egr problem...i think?
Old Apr 6, 2009 | 09:36 PM
ford4x4956's Avatar
ford4x4956
i have 05 f250 6.0....poor performance, alot of smoke....any suggestions??
Old Apr 7, 2009 | 12:00 AM
79_custom's Avatar
79_custom
could be ERG Could be coking in the turbo causing the vains and unsion ring sticking. Do you have problems starting when cold?
Old Apr 7, 2009 | 12:10 AM
ford4x4956's Avatar
ford4x4956
nope starts just fine...just hesitates to take off then runs fine but alot of smoke
Old Apr 7, 2009 | 12:16 AM
79_custom's Avatar
79_custom
you also could have a hose on the Hot side of the turbo busted open check all blue hoses , that would also cause smoke and poor proformance. Check both the hot side and cold side of the CAC tubes. ESP on the black plastic tubes on the driverside. down under the air filter assy, where the according crinkle section is, there bad to get holes there also.
Old Apr 7, 2009 | 12:02 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the 6.0 forum - WELCOME to FTE!
these guys will take good care of you.
Old Apr 7, 2009 | 01:43 PM
steelhead2's Avatar
steelhead2
what color smoke?.might be a stuck open egr valve.
Old Apr 7, 2009 | 07:11 PM
krommag's Avatar
krommag
it might be the MAF sensor, mine went out and it was smoking and runing rough when it was at operating temp,
Old Apr 7, 2009 | 07:15 PM
ford4x4956's Avatar
ford4x4956
thnaks for the replys....well i disconnected the egr and the truck is working fine now but blowing white smoke and coolant from the reserve...hopefully its not the hg
