Sponsored by: Auxito
How can I...
Old Feb 5, 2015 | 11:29 PM
FordTruckChuck's Avatar
FordTruckChuck
Lightbulb How can I...
Any suggestions on a temporary way I can prevent snow from accumulating in the bed of my truck during a storm? I'm not enjoying having to shovel it out.
Old Feb 5, 2015 | 11:51 PM
Tedster9's Avatar
Tedster9
Not really. Some weight is beneficial. Bad (melting) if an attached garage though. Toppers or "caps" keep the snow out. Maybe a sheet of plywood.
Old Feb 6, 2015 | 07:03 AM
Spotty's Avatar
Spotty
Couple sheets of 3/8ths OSB would be cheap. It would be all delaminated and basically junk by the end of the season, but would help. As long as you remember to toss them off before you leave. Craigslist is full of cheap shell toppers that you could clamp on just for the winter.
Old Feb 6, 2015 | 11:44 AM
2Fords1Jeep's Avatar
2Fords1Jeep
Buy a tonneau cover. Lund makes a nice cover for around 200
Old Feb 6, 2015 | 04:16 PM
FordTruckChuck
Thanks guys for the ideas. Hadn't thought about particle board. It's not has heavy as plywood(right?) so it'd be easier to handle. Suppose I could run a strap side to side to keep the wind from blowing it off. I have a tool box mounted but I think 2 sheets would still be needed.
I should've mentioned that the reason for wanting no snow in the bed is to be able to load my snowblower in it. And would be needed only when the truck is parked in my driveway.
Old Feb 6, 2015 | 04:58 PM
Spotty's Avatar
Spotty
Particle board is heavy stuff, OSB (oriented strand board) is a little lighter than plywood, 3/8ths is not real heavy. If you have a toolbox and a 6.6 bed you will need to cover about 60". You will need at least 72" long to cover side to side. That would leave you with a piece 48"x24". Rip that in half and cut one 24" shorter and it will all be covered. You'll need to join those two together with a 1x4 underneath or whatever you can find. Not real strong or pretty but should keep the snow out. If it bows down too much with snow load you can always screw a couple 2x4's under it as a strut to keep it rigid. Probably less than $12.00 for the whole project. Throw a few bricks along the edges while parked to keep it from blowing off....or whatever you got. LOL....I'm an old nail bender so I don't like waste.
Old Feb 6, 2015 | 05:02 PM
projectSHO89's Avatar
projectSHO89
I park the truck in the garage if I want to keep snow out of it. Works every time!
Old Feb 6, 2015 | 05:35 PM
Spotty's Avatar
Spotty
I quit doing that years ago because of the mess....drives me nuts. The garage stays about 32* even on -20 nights and it is like a swimming pool in the morning. My wifes car doesn't drip much of a mess, but my truck does. A floor drain is useless because it freezes up unless you heat the **** out of the garage. Hi-jack over.
Old Feb 7, 2015 | 06:03 PM
FordTruckChuck
Thanks, Scotty.
I don't quite understand how to go about cutting the 4 x 8 sheets to the size I need. Could you explain abit simpler?
My truck has an 8' bed with a standard size tool box mounted at the front. I suppose it would help if I had the measurement of the area I want to cover. I'll get that.
Old Feb 7, 2015 | 06:38 PM
Spotty's Avatar
Spotty
Yeah....I was figuring for a 6'6" bed. Sounds like you have an 8'. Get the area and I'll help you.
Old Feb 7, 2015 | 07:21 PM
FordTruckChuck
The Size
The size is 68" x 74"
Old Feb 7, 2015 | 07:39 PM
Tedster9's Avatar
Tedster9
For long term solution , Florida or Arizona would be good.
Old Feb 7, 2015 | 10:37 PM
kd4gij's Avatar
kd4gij
What is this SNOW you speak of??? I have never had snow build up in the bed ov my truck.
Old Feb 7, 2015 | 11:23 PM
FordTruckChuck
Talking
Oh wow! You don't know what you're missing out on! It can be alot of fun to play in.
You probably don't know what 4 wheel drive is either.
Old Feb 8, 2015 | 09:11 PM
kd4gij's Avatar
kd4gij
Shure we use 4 wheel drive to play in the mud or sand down here. But no I don't have one now. To old
