Sponsored by: Auxito
How can I...
Old Feb 11, 2015 | 04:45 PM
FordTruckChuck's Avatar
FordTruckChuck
Smile Dimensions
Originally Posted by Spotty
Yeah....I was figuring for a 6'6" bed. Sounds like you have an 8'. Get the area and I'll help you.
The size is 68" x 74"
Old Feb 12, 2015 | 01:28 PM
Spotty's Avatar
Spotty
About all you can do with that size is 2 sheets of 4'x8'...I would use 1/2"...of oriented strand board or plywood ...both weigh about the same...plywood will be more $$. Cut each sheet at 6' and then just overlap the seam and weigh it down with whatever you got. Then just toss it off when you drive the truck..or toss it in the bed.
Old Feb 13, 2015 | 01:53 AM
FordTruckChuck
Thanks Spotty.
I bought 2 sheets of OSB. I don't remember the thickness off hand but I know it's not 1/2". Maybe 7/16"? The cutting sounds easy enough. I was thinking that it would not be good to put weight on them. So I was considering running a strap from one side to the other & hooking on to something under the truck. Hmm. Now that I think about it, that would need to be a rather long strap or two. Maybe I should attach eyelets on each end & hook onto them. I did by 2 utility handles to help with handling them.
Old Feb 13, 2015 | 10:36 PM
kd4gij's Avatar
kd4gij
Now you will have to shovel the snow of the plywood so you can remove it.
FordTruckChuck
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Feb 6, 2015 10:38 AM
dalspot
6.7L Power Stroke Diesel
21
Sep 8, 2014 06:11 PM
RickBetterley
Sep 22, 2011 08:19 PM
cheese74
Nov 13, 2006 07:23 PM
lamennais
2004 - 2008 F150
Dec 20, 2003 11:43 PM
