Sponsored by: Real Truck
Oil heater
Old Feb 5, 2015 | 05:08 PM
NHRA racer 303's Avatar
NHRA racer 303
Oil heater
Engine guide states to use block warmer when temp's dip below -10. I was just curious as to how long you need to run it. So i dont have to leave it on all night. Was going to put it on a timer tonight. Or is it just better to just leave it on. And how do you know it on. Was just curious in case it failed. How would you know it wasnt working.
Thanks
Steve
Old Feb 5, 2015 | 05:12 PM
redford's Avatar
redford
FTE Leadership Emeritus
Most guys use a timer and just run it a few hours before they have to leave.
Old Feb 5, 2015 | 05:31 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
It's not an "oil" heater though.
It heats the coolant.
Some do leave the heater on all night, some on the timer.
You would know if it is working if you start the truck and the heater works right away and there is some temperature showing on the gauge.
Old Feb 5, 2015 | 06:35 PM
NHRA racer 303
Absolutely correct Ltngdrvr. It is a coolant heater. I thought i read some where that it was an oil heater. I was looking for the information in the owners guide supplement. The coolant warmer info was in the owners guide in the driving section. The warmer reaches maximum temp in 3 hours. Any more than that will not make it any warmer. And is just a waste of electricity. And it pulls between 400 and 1000 watts. So its worth investing in a timer.
Thanks for the info guys. I appreciate it. Keep your blocks warm.
Steve
Old Feb 6, 2015 | 06:48 AM
Tom's Avatar
Tom
I used to put it on a timer for about three hours.
None of my trucks would get that warm on the block heater. It's a 900W heating element tasked with warming a 1,000 lb chunk of metal sitting in ambient air temps below freezing.
I never saw above around 65° ECT after a few hours, which wasn't enough to move the needle.
Old Feb 6, 2015 | 07:38 AM
sxrfun's Avatar
sxrfun
Same as everybody else here...roughly 3 hours as well for the block heater. If you still have your egr coolers in place...you can pop the hood and touch the upper cooler..it'll be warm if the block heater is working. Assuming of course you have the 6.4L that is. Another thing you can do is when you first plug it in....go to passenger side wheel well and have a listen....you'll hear a bubbling sound when it first heats up...sort of like a kettle when you first turn it on.
Old Feb 6, 2015 | 09:22 AM
Iaff113's Avatar
Iaff113
Usually I plug mine in the nights before I have to go to work. When it's under 30 outside. I see Usually see an oil and coolant temp between 80 and 90F in the morning
Old Feb 6, 2015 | 10:07 AM
thomabb's Avatar
thomabb
Some thoughts...
If you are going to use a timer, make sure you get one that is rated for the amps you are going to pull through it.
Keep the prongs at the end of the cord clean. They are exposed to the elements and will crud up.
Use a heavy duty exterior rated extension cord. Get a cord that isn't longer than what you need.
A lot of guys on here plug their block heaters into a GFCI outlet. Not a bad idea.
Old Feb 6, 2015 | 12:26 PM
droldsmorland's Avatar
droldsmorland
Plug it in at night...unplug before you drive it. Thats what its designed to do. I Plug mine in at 30*F. Make sure you take proper measures to secure both the extension cord and the truck pig tail. So when you forget to unplug it it simply uncouples without ripping anything out.
Old Feb 6, 2015 | 02:07 PM
Tom's Avatar
Tom
That would cost nearly $50/month with our electric rates out here. I really don't see a reason to leave it plugged in all night. Mine started fine at -10 without the heater, but my fuel economy had a noticeable improvement when plugged in for two hours.
Old Feb 6, 2015 | 02:13 PM
Skip1970's Avatar
Skip1970
i got a heat pad epoxied to my oil pan that heats the oil. then i also heat the coolant.
desertt5
Jan 7, 2010 03:56 PM
jakemb
Feb 11, 2007 07:52 AM
Fordbronco69
18
Dec 24, 2004 06:20 AM
RogueRiverRat
25
Dec 5, 2004 01:25 PM
ajc766
Jan 11, 2004 06:41 PM
