Build ideas and help
Old Feb 4, 2015 | 08:11 PM
Mac78's Avatar
Mac78
Ok so I am getting ideas to build my truck I have about 3500-4000 to put into the engine including any machine work that I need to get done. I want to be able to get between 225 and 250 hp out of it. Just looking at turbo kits I think they are out of the question due to cost. So my question is what should I do to it to make that kind of power in my price range?
Old Feb 4, 2015 | 09:02 PM
Mac78's Avatar
Mac78
Can I even get that kind of hp without a turbo
Old Feb 4, 2015 | 09:08 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
dang, you should be able to get 300 or so with that kind of dough. There are a lot of build threads on here, but if you want HP, you gotta go turbo. Look for a used turbo, and check out R&D IDI Performance With a solid bottom end, a cam, pump, injectors and a turbo, you should easily achieve you goals.
Old Feb 4, 2015 | 09:54 PM
sjwelds's Avatar
sjwelds
No. IMO no chance.
Old Feb 5, 2015 | 09:13 AM
southtexasidi's Avatar
southtexasidi
A 110cc pump from R&D, good efficient turbo, and all the supporting mods should put you where you want to be
Old Feb 5, 2015 | 05:55 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Alot of nitrous... not sure what the engine would have to say about that though.
If youre talking engine horsepower, aka brake horse power, you might get 225 with a bunch of work and $$, would be easy to eclipse that with even a stock type turbo for 400-600 bucks used.
S360 turbo kit, 90cc pump, IC kit, and stage 1 cam from R&D will give you 240/250whp and close to 600lb/ft. 110 pump is a little more, will also need studs, and i would run the 363 and that should give you 290-300 and 650-700 to the ground. Wouldnt have to run an IC for 90cc, but it will run hotter and you wont get quite as much powas
mrend419
Sep 11, 2014 11:14 AM
mitchell390
15
Oct 6, 2012 04:04 PM
1973dieselhighboy
18
Sep 21, 2010 08:48 PM
ruffneck22
Apr 6, 2009 01:31 PM
RapidRuss
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
21
Jul 5, 2004 07:42 PM
