Coolant Question.
Old Feb 4, 2015 | 12:12 PM
InAVanByTheRiver's Avatar
InAVanByTheRiver
Coolant Question.
Ok so Ive gone around and around reading about coolants and sca's. About to do a coolant flush in my 01' 7.3, and I purchased Zerex G-05 last night. Well now after reading SpringerPops write up on the external coolant filter I am questioning the sca's again. Am I doing the right thing using Zerex G-05 or should I be using Peak Fleet Charge in it? Any direction on this would be appreciated.
Old Feb 4, 2015 | 12:35 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Zerex G05 is the same as the Motorcraft Gold coolant. I dont know how Peak Fleet Charge lines up, but it is also an SCA coolant, so using that wouldnt fix any problems.
If you dont want SCAs use a CAT EC-1 rated HD Extended Life Coolant (ELC).
SCAs arent too much of a problem in a 7.3L, but they can cause problems in 6.0Ls. They just require maintenance in a 7.3L and, if you are so inclined, a filter too.
I have HD ELC and a filter. For the record.
Old Feb 4, 2015 | 12:38 PM
hydro man 17's Avatar
hydro man 17
If you go with one of the CAT EC-1 rated coolants you don't need to worry about the SCA issue, and no need for a filter either - as far as I am concerned. (this will stir some controversy). What most refer to as "casting sand" is actually silica precipitating out of the more conventional coolants because they have not been kept in proper balance. As far as casting sand is concerned I doubt that any significant amount is left in the block before they even begin doing any machine work, if in fact they still use sand in the casting process. I did some research on this but could not come up with any solid info one way or the other.
Old Feb 4, 2015 | 12:49 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Both silica and sand are present in the engine. I put my coolant filter on after switching to ELC and still caught sand, although obviously once its filtered out, you dont need to worry about it again.
I dont think the sand is too big of an issue.
parcours
2009 - 2014 F150
Dec 21, 2015 08:53 PM
EcoboostKev
Aug 18, 2015 02:07 AM
Headviking
May 17, 2012 10:42 AM
96 Power Stroked
Jan 11, 2006 06:36 PM
Pastmaster
Nov 26, 2002 02:29 PM
