I just tested the GP's with an ohmmeter and all but one of them appear to be working. However, lacking on GP should not be causing this significant of an issue. The GPR checks out on the 2 larger posts, but the smaller post that should have power when the switch is on does not. I just started the truck after a medium length cranking sequence. Before doing so, I let the GPR run until the buzzing slowly faded away. The truck started after this and ran fine. However, after shutting it down, waiting a few minutes and trying again, I got nothing. This time, the GPR buzzed loudly then "clicked" off. No start...
disconnect the small control wires on the gpr and tape them up separately. Check fuse 22 and see if that helps
According to all that I've read, when the key is "ON", there should be power on the smaller post closest to the passenger side on the GPR. At no point, even when I had it running briefly, was there power on that post.
What color is the wire on that terminal? It's useless to go by physical position, because neither the coil circuit nor the contact circuit of the GPR are polarized, and the wires may have been switch by some PO. If it was the red/green wire you tested, then yes, it should have voltage whenever the key is in the RUN position. That circuit also energizes the PCM, so if you are getting the WTS light, the circuit itself is good.
But just to eliminate any GPR issue, and to eliminate the other major issue with that circuit (fuel filter heater), disconnect that red/green wire (and tape it off) as suggested above. Also disconnect the fuel filter heater. Same color wire, flat blade single terminal connector on the driver's side of the fuel bowl. THEN, connect a jumper cable between the two big terminals on the GPR (or, alternately, from the battery positive to the "load" side of the relay, the terminal that goes to the GPs). Have it on for 10-15 seconds to energize (or at least it SHOULD) the glow plugs. Then remove it, and go try to start the truck.
Do you have a decent charge in the batteries at this point?
The reason I suggested disconnecting the gpr is to isolate any power draw or return from the PCM. I'm not going to say it will do anything it was just a thought is all.
^^^^ Good idea; the GPR has even been know to fail such that it crosses the coil and contact circuits, so it's always energized. And it will even "backfeed" power to the PCM even when fuse #22 is blown. So disconnecting it might make such issues apparent.
Right now, with the new GPR, the WTS comes and goes much faster. Both wires going to the small posts are red. The charge is getting weaker, but it still cranks fine. I'm probably going to throw a charger on there for the night and get a new CPS tomorrow. I was talking to a buddy, and he suggests that the EBP sensor might be messed up. I hate to keep throwing money at this, and even with a code reader, I don't know what help it would be.
Check the wiring to the IPR pigtail and make sure it's not rotted away from diesel fuel. Maybe juggle the pigtail and try to start again. If it starts, jiggle those wires and see if it shuts down. Ask me how I know this.
