need help
Old Feb 3, 2015 | 04:46 AM
brutus67's Avatar
brutus67
need help
hey guys I don't know if there is a thread on this subject but I want to convert my three on the tree to automatic gonna run a c4 question is the brake pedal. can I just cut the clutch pedal off flush where it mounts I have never done this on a truck before sorry to be a pain thanks in advance for any help
Old Feb 3, 2015 | 08:57 AM
Ozarktraveler's Avatar
Ozarktraveler
You can cut it, you can let it lay on the floor, or you can remove it entirely.
Old Feb 3, 2015 | 09:10 AM
fe390pc's Avatar
fe390pc
You will need a column out of an automatic truck, so grab the pedal while you are there.
Old Feb 3, 2015 | 09:18 PM
brutus67's Avatar
brutus67
need help
thanks guys I was going to get a fully reconditioned auto column from tom at flashback f100,s so I might ask him when I order my column about finding one for me the brake pedal on an auto is a slightly wider pad if I am not mistaken anyone chime in if you know as always thanks for all your your help this is a great forum I have always found everyone very helpful
Old Feb 4, 2015 | 04:58 AM
jowilker's Avatar
jowilker
brutus67, I still have my original 3 on da three brake pedal in my 66 after converting to auto C6. It has been a dozen plus years ago, but the hardest part was removing the clutch return spring.
Should you be thinking a disc brake power steering upgrade, I would hold off and swap in the tranny at the same time. You will need a different shorter column.
Just make a plan before you jump in and have a column that you need to sell.
John
Old Feb 4, 2015 | 05:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
thanks guys I was going to get a fully reconditioned auto column from tom at flashback F100's, so I might ask him when I order my column about finding one for me.
The brake pedal on an auto is a slightly wider pad (1973 and later).
1967/72 F100/350: The brake & clutch pedal pads are the same width and part number (B7A-2457-A).
Beginning in 1973: With A/T, the brake pedal pad is wider (D3TZ-2457-A) than the clutch pedal pad (B7A-2457-A).
1968/72 F100/350: The brake pedal (C8TZ-2455-E) is the same with A/T & M/T.
With M/T, the brake pedal rides on the shaft of the clutch pedal. With A/T, there is a separate shaft that the brake pedal rides on.
newguy399
May 9, 2016 09:38 AM
DGMFORD
Nov 11, 2012 01:31 PM
Lwlandy
16
Oct 1, 2005 09:25 AM
hirschi
Mar 20, 2002 07:02 PM
