roller cam
Old Feb 2, 2015 | 07:07 PM
69issofine's Avatar
69issofine
roller cam
how do you put a roller cam set up a 70 390 or is it possible?
Old Feb 2, 2015 | 10:20 PM
GRoper's Avatar
GRoper
Cam lifters and pushrod timing chain. http://www.summitracing.com/search/P...roller-tappet/
Old Feb 2, 2015 | 10:27 PM
HIO Silver's Avatar
HIO Silver
With the utmost in mechanical workmanship and attention to detail.
Old Feb 2, 2015 | 10:36 PM
GRoper's Avatar
GRoper
Wink wink......
Old Feb 3, 2015 | 04:21 PM
CougarJohn's Avatar
CougarJohn
69, you work from inside the cab. Remove dashboard and all wiring, drill through the cab, pull bell housing, drill through the back of the block, pull everything back. Work from the inside, a piece of cake. Caulk the block hole up tightly, re-install, rewire.
Come on back in if we can help you through the job.
Old Feb 3, 2015 | 05:37 PM
flyboy2610's Avatar
flyboy2610
From "The Hunt for Red October":
"Can you launch an ICBM horizontally?"
"Sure, you can. Why would you want to?"
Old Feb 3, 2015 | 06:39 PM
Rasputin53's Avatar
Rasputin53
CJ you are killing me!
Old Feb 3, 2015 | 10:50 PM
orich's Avatar
orich
Buy a book or 2 maybe 3 on how to build a roller motor and Read & read some more re-read what you just forgot.
Then were here for you.
Orich
Old Feb 3, 2015 | 11:05 PM
GRoper's Avatar
GRoper
I hope he's a troll. If he's not he should be.
Shwan_89HD
Oct 4, 2013 05:29 PM
xfordman
4 Cylinder Engines
Oct 19, 2010 07:57 PM
dutchboy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 6, 2004 02:07 PM
thenkel2
Mar 27, 2001 03:36 PM
