Break Issues!!
Old Feb 2, 2015 | 06:52 PM
JMalmy21..00/7.3's Avatar
JMalmy21..00/7.3
Break Issues!!
Soooooo here is the gist of it all-
The break pedal has to go ALL the way to the floor in order for the braking to begin.
Bled the breaks and only the front 2 breaks bled.
The rear 2 breaks apparently arent getting any sorta of pressure so they arent engaging at all....
Master cylinder issue??
HELP! lol
Thanks!!!
Old Feb 2, 2015 | 07:04 PM
F350-6's Avatar
F350-6
Just for clarification, how are you bleeding the brakes?
You'll have to start with the rear passenger side and bleed the brakes until you get fluid coming out of the caliper with no air bubbles. If you don't like the old fashioned 2 person way, speed bleeders, the DIY bottle kit, mighty-vac, or several other vacuum options are available to make it easier and a one man job.
Old Feb 2, 2015 | 07:15 PM
JMalmy21..00/7.3
Does it matter if you start w the right passenger?
Old Feb 2, 2015 | 07:16 PM
F350-6's Avatar
F350-6
In order to make sure you get the air out of the lines, it's best to start with the wheel furthest from the master cylinder.
Old Feb 2, 2015 | 07:59 PM
JMalmy21..00/7.3
All makes perfect sense. Thanks!
Dlasure2
Oct 12, 2020 11:04 PM
0351mike
1997 - 2003 F150
Sep 17, 2012 11:30 AM
octaneforce
Jan 16, 2012 01:12 PM
93XLT150
Feb 13, 2011 05:51 PM
Sixoh
Sep 1, 2004 08:33 PM
