Code 327
Old Feb 2, 2015 | 04:37 PM
chesster51's Avatar
chesster51
Code 327
Check engine light comes on randomly and usually last about 3 - 5 seconds and then goes off. May stay off for several minutes but eventually does it again. Bought a reader and found code 327. I see that it is EGR related. I've only had the truck 2 months and see that it has a new EGR unit installed and was done at a shop a couple of months ago according to the service records that came with the truck. I've looked at the green vacuum line and it appears to be in good shape. What can I do to find what's causing the code?
Old Feb 2, 2015 | 08:56 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
When a code is set, it can point directly to a faulty component, or it can be indicating that something is pushing the suspect component outside it's normal operating range. In the case of an EGR valve, the problem could be in the electrical connections or it could be deteriorated plumbing. Check all the related hoses. make sure you have an EVTM on hand for reference.
Old Feb 2, 2015 | 10:16 PM
chesster51's Avatar
chesster51
Thank you for the response, what's a EVTM?
Old Feb 3, 2015 | 07:31 AM
rla2005's Avatar
rla2005
Electrical and Vacuum Troubleshooting Manual
Code 327 indicates the closed EGR feedback signal is too low. You never indicated if the Code was displayed in the KOEO tests, CM display or KOER. If it is from CM (Continuous Memory) that means it has happened in the past. Try clearing the codes then drive the truck again to see if it returns.
If it does return then get a meter to measure the EGR position signal from the EGR Valve Position (EVP) sensor (Key On, Engine Off). Should be above 0.2 VDC.
Old Feb 3, 2015 | 01:02 PM
chesster51's Avatar
chesster51
Code was taken KOEO. I'll clear the code when I get home and see if it returns. Thanks a ton for the help.
Edit: Is the EVP sensor the one the green vac hose connects to at the coil bracket?
Old Feb 3, 2015 | 02:26 PM
rla2005's Avatar
rla2005
No, the green vacuum line is for the EGR valve, it's vacuum operated. The EVP sensor sits on top of the EGR valve. It sends a voltage feedback signal to the computer PCM.
For reference: Fuel Injection Technical Library » EGR Valve Position sensor (EVP)
Old Feb 5, 2015 | 06:02 PM
chesster51's Avatar
chesster51
Checked the voltage at the EVP sensor and it was good, so I replaced the sensor and all is good now. Happy day and thanks for the help.
Old Feb 5, 2015 | 07:16 PM
rla2005's Avatar
rla2005
Glad to see it is resolved.
scrobbie
Jan 27, 2014 07:10 PM
Fordfr4x4
Mar 13, 2013 04:53 PM
danboy282
Bronco II
Jan 30, 2012 10:21 AM
rwdfan
21
Jan 12, 2010 12:26 AM
daw1264
1997 - 2003 F150
Feb 7, 2002 07:30 PM
