Sponsored by: Real Truck
Tie Rod
Old Feb 2, 2015 | 08:29 AM
Vinford's Avatar
Vinford
Tie Rod
2002 F-350 4x4 diesel
Had to walk out of the bush last night , hit a stump and broke tie rod.
Im guessing I only have to buy the long side , does anyone know by looking at picture?
It looks like it comes apart right near where its broken?
How hard is going to be to get long side off.
The truck is sitting in fairly deep snow, no way to get a tow truck to it.
Old Feb 2, 2015 | 08:43 AM
Iaff113's Avatar
Iaff113
Should just have to take the nut and clip of the other tie rod and pull the entire bar out.
If it was me after hitting something I would replace both tie Rod and the Center bar
Old Feb 2, 2015 | 08:50 AM
Vinford's Avatar
Vinford
Its not hooked to a ball joint type of deal on passengers side?
Old Feb 2, 2015 | 08:51 AM
Iaff113's Avatar
Iaff113
Ok I thought it was a straight bar with two tie rods.
Old Feb 2, 2015 | 09:42 AM
Vinford's Avatar
Vinford
So is anyone familiar with what tie rod it might be?
Its a long ugly road I have to go back in too look, plus no turnaround Ill have to back out about 3kms
Old Feb 2, 2015 | 09:45 AM
Super Duty DJ's Avatar
Super Duty DJ
Doing a bit of looking, you will need to buy the broken part in order to get the truck out. It is attached to the steering knuckle on the passenger side with a ball joint and the steering drag link, which can be seen with the other adjusting sleeve in the upper left portion of the picture, is attached to the tie rod with a ball joint type connection as well. A good pickle fork and hammer should separate both of those connections for you without too much difficulty. After you get it back to civilization, you would definitely want to replace the short side tie rod end as well and get an alignment.
Old Feb 2, 2015 | 07:29 PM
Vinford's Avatar
Vinford
Well go a better road plowed to it and made a spot to work on it.
Didn't come apart real easy but got it , only to find out I had gotten the wrong tie rod end.
Well tomorrows another day , another try......................
Old Feb 3, 2015 | 06:10 AM
redford's Avatar
redford
FTE Leadership Emeritus
Crud...hate it when that happens. GIven a 50/50 chance of getting it right, I always end up with the wrong part.
Old Feb 3, 2015 | 08:52 AM
Tedster9's Avatar
Tedster9
Easy way to solve that problem - just buy both of them (And then i'd find they are for the wrong truck, the argentinian export model or something)
ROCKETFORD
Jul 29, 2017 04:10 PM
Mac452
Aug 4, 2014 02:47 AM
devozoo
1997 - 2003 F150
Jun 22, 2006 07:11 AM
kjett
Dec 30, 2003 06:50 AM
