light problems pls help
Old Jan 31, 2015 | 06:50 PM
terby348's Avatar
terby348
I have a 2005 ford f250 I recently bought we took it all apart and had it all painted and bought a new bed for it cause old one was bad we are putting a 2011 bed on my 2005 and we put it all together and now the rear lights don't work Anyone have any idea on how to fix this problem pls help asap
Old Feb 1, 2015 | 07:29 AM
Franklin2's Avatar
Franklin2
Usually when people paint things up really nice, they lose the grounding. Pull the taillights and see how they are grounded. If the ground bolts to the sheetmetal inside the bed cavity, you may need to take the ground wire off and and scrape away some paint where it bolts on. Same with the frame. If the wire or another wire bolts from the harness to the frame, you need to scrape away the paint so it makes good contact to the metal.
grandpas 51 f1
Nov 24, 2017 07:51 AM
joe84ford
May 22, 2016 11:31 AM
erniesshop
Aug 8, 2010 11:40 PM
66f-100
Jan 3, 2009 03:47 PM
bddo
May 30, 2003 04:42 PM
