Dumping my no-name chip!
Old Feb 7, 2015 | 12:53 PM
  #31
oldbird1965's Avatar
oldbird1965
I know your not faulting me Todd nor do I feel your unreasonable. I said I feel the same way but I have conflicting feelings about the situation. I always get carried away in my reply's and if I implied that I was not happy with your reply, sorry! I also feel their Honey Badger Jr. hpop is superior to Joey's. I haven't tested it enough yet but so far have seen some good numbers, better then the T500. Maybe its just the bigger diameter high pressure hoses I got from him allow more oil to flow? I also heard if you get a adrenaline, stealth or honey badger jr., tuners will adjust your tuning. If you get a T500, they will not bother adjusting. I'm sure these last two sentences will be debated, just what I heard!!
Edit: I got Bill's OK to run dyno's tunes, LOL
Old Feb 8, 2015 | 09:26 AM
  #32
ProjectDually's Avatar
ProjectDually
Glenn, do you have any data, or a side by side comparison to show this? I know a lot of guys run the T500, and do see results. The only place I've seen the HB Jr. is on Ebay. I guess I haven't looked hard enough for it though, since I was pretty much set on the T500.
Old Feb 8, 2015 | 09:34 AM
  #33
oldbird1965
No John, no data, just the butt gauge and aeroforce gauge. I didn't have the AE when I had the T500.
Old Feb 8, 2015 | 09:41 AM
  #34
ProjectDually
Ah, makes sense. Glenn, you did mention bigger oil lines. How much bigger over stock would you say they were? I know that being able to push a bigger volume of fluid through a bigger hole might have something to do with the SOTP's feeling that you are getting from the HB Jr.
I guess the same would go for using bigger fuel lines to feed your injectors when you did the E-fuel, you went bigger than stock ID lines right?
Old Feb 8, 2015 | 09:56 AM
  #35
oldbird1965
I don't know how much bigger the ID is but was told the fittings on the pump are bigger also. The hoses are rated at 5000 psi and were a bit hard to bend to get them installed. As far as the e fuel, I used Irate's kit.
7.3L Upgraded HPOP Lines - 7.3L - Engine - -Ford- Power Stroke - PARTS
Old Feb 8, 2015 | 10:00 AM
  #36
ProjectDually
Thanks, I'll make sure to check them out! Oh, did you try another WOT run with AE yet?
Old Feb 8, 2015 | 11:59 AM
  #37
oldbird1965
No, I haven't yet John. Both my daughters are visiting and they leave Tue, then I'll try another run.
Old Feb 8, 2015 | 12:01 PM
  #38
ProjectDually
Ah well have fun with your kids Glenn!
Old Feb 11, 2015 | 08:13 PM
  #39
compaddict's Avatar
compaddict
Received the new chip, installed it and WTS light stuck on.
Put the old chip back in and good to go.
Sending it back.
Old Mar 4, 2015 | 02:23 PM
  #40
compaddict's Avatar
compaddict
Got my refund from Tony Wildman, less restocking fee but whatever.
Sticking with my noname chip.
Old Mar 5, 2015 | 06:42 AM
  #41
fordman67's Avatar
fordman67
It didn't work..they did not offer to make it right?
Old Mar 5, 2015 | 07:42 AM
  #42
coreyallan01's Avatar
coreyallan01
Not that it makes any difference now but I had to send mine back to Jody after his innitial burn.. Im sure its not that uncommon for one reason or another to return one for a reburn...
Old Mar 5, 2015 | 07:47 AM
  #43
fordman67's Avatar
fordman67
Technology sucks...
Old Mar 5, 2015 | 09:45 AM
  #44
compaddict's Avatar
compaddict
I lost confidence. For that much money it should have worked out of the box.
Old Mar 5, 2015 | 09:57 AM
  #45
oldbird1965
How did you get ahold of him? I've had his chip for seven years and have a h*ll of a time getting him to communicate. I want a reburn now and have sent him several emails to no avail.
