Is your Bed Lined Up?
Old Feb 1, 2015 | 06:13 AM
gwcon's Avatar
gwcon
Mine are lined up. Must not have been assembled on a Monday or a Friday. LOL
Old Feb 1, 2015 | 06:45 AM
T diesel's Avatar
T diesel
My drivers side cab was about 3/8" low.
They shimmed the cab with two galvanized washers in about 5 minutes and now it's perfect.
I think this issue mostly effects supercabs.
**** POOR quality control.
Old Feb 1, 2015 | 10:41 AM
jh225's Avatar
jh225
Originally Posted by EO2SeaBee
After reading this thread yesterday, I looked at mine more closely in the parking lot when leaving work. Mine is straight vertically and horizontally. The body line is straight between the cab and bed, and the cab sides and bedsides are flush with each other on both sides. For what it's worth though, I have read multiple times of this exact same complaint on the Ram forums too, so it's not just Ford that can't get the jigs lined up correctly during installation.
Thought some more about it and now am getting more annoyed.
Being that the passenger side body lines and bed side to door are all lined up correctly, when I loosen the bed bolts and try to get the driver side to line up, it is going to throw the passenger side off.
The only way I can see getting the driver side to line up is by leaving the passenger side bolts tight, loosening the drivers side and trying to "stretch" the bed side.
I could also swear that this was not like it now is on day 1. I am 99.9% sure I would have picked up on it while either waxing or towing a trailer by seeing it in the mirror. I noticed the current position while looking in the side mirror to check a load of flooring (maybe 600lbs) in the bed.
Absolutely ridiculous.
Old Feb 1, 2015 | 12:54 PM
T diesel's Avatar
T diesel
I don't think it's the bed.
Mine was a low driver's side cab.
Old Feb 1, 2015 | 01:36 PM
jh225's Avatar
jh225
You mean the bed was low (not vertically aligned) or the truck sat lower on the driver side? Mine and many others have noticed the driver side does indeed sit lower.
However, my bed is lined up (body line wise), but is a good 1/2"-3/4" out of alignment, panel wise. (cab to bed)
Old Feb 1, 2015 | 02:42 PM
T diesel's Avatar
T diesel
The driver's side cab, just like the op's photo's.
Old Feb 1, 2015 | 06:33 PM
jh225's Avatar
jh225
I understand that your cab was low, but that is not my (the OP) trucks issue and what you think the photo's show is not is reality. My body lines (vertical) are close to perfect, it is the left to right (horizontal) that is way off.
Old Feb 2, 2015 | 07:40 AM
93-331-29PSI's Avatar
93-331-29PSI
I have a '15 as well and while the body lines are spot on, it appears to me that the bed itself is narrower outside edge to outside edge than the cab. If I were to put a straightedge on the cab there is about a 3/16" gap between the straightedge and the bed on both sides.
Old Feb 2, 2015 | 10:20 AM
jh225's Avatar
jh225
I would be OK with that if the gap is the same on both sides. What I can't understand is how they got one side correct and the other is at least a 1/2" off. So in reality if I move mine, it would be like yours.
Old Feb 2, 2015 | 10:31 AM
jh225's Avatar
jh225
***QUESTION***
If I remove my bedliner to expose the bed bolt heads, and I loosen all the bolts a little, will the bed then have any side to side play?
In other words, are the holes precise or are the somewhat oversized?
Old Feb 2, 2015 | 01:23 PM
golfmedik's Avatar
golfmedik
There is a little room for movement.. Not much, but enough to tell a difference from the side.
Old Feb 2, 2015 | 08:41 PM
jh225's Avatar
jh225
Thanks. Hopefully it is enough so that it at least looks better.
79 F-150 Stone
Mar 31, 2018 05:19 PM
WallaceSF
13
Jan 27, 2018 06:16 PM
dthut
Mar 13, 2017 03:58 PM
65fordguy
Aug 31, 2008 08:24 PM
