Overheating !!!
Old Feb 4, 2015 | 04:17 AM
  #31
Aussietruck's Avatar
Aussietruck
Thank you
Thank you to every one that has contributed to this thread!!
Just picked the truck up from the mechanic and they have put a new water pump in plus re flushed the cooling system and installed a highflow thermostat !!! All at cost price thank god, I must say they have been good to me in that respect ....
I was also reading about partially blocked cat converters causing overheating! Not educated on this at all but figured it might be worth taking the truck in to have the exhaust checked before the next big trip in 2 weeks (more for piece of mind, would rather that than breaking down 8hours from home )
Hopefully we have resolved the problem and have a good trip 😊 will post again with the result 😉
Old Feb 4, 2015 | 04:43 AM
  #32
jhl3's Avatar
jhl3
Hopefully the issue is resolved.
A clogged Cat would probably cause above normal exhaust back pressure. Can you monitor that?
Old Feb 4, 2015 | 04:57 AM
  #33
senix's Avatar
senix
plugged cat would cause it to run poorly.
Old Feb 4, 2015 | 06:00 AM
  #34
jhl3's Avatar
jhl3
Yes. Lower power and higher heat. Just looking for a way to diagnose a plugged cat without having to cut into the exhaust.
Old Feb 4, 2015 | 06:31 AM
  #35
CampSpringsJohn's Avatar
CampSpringsJohn
I would be surprised if it has a cat. But a freed up exhaust certainly won't hurt anything! Be that as it may, my bet is that the water pump was the problem.
Old Feb 4, 2015 | 06:45 AM
  #36
jhl3's Avatar
jhl3
Originally Posted by CampSpringsJohn
I would be surprised if it has a cat....
I agree. However, I had one on this e99. I can't find a pattern as to why some had them and others didn't.
Old Feb 4, 2015 | 08:56 AM
  #37
Tugly's Avatar
Tugly
I have no idea what the laws are in Australia, so they may very well have cats. Monitor the EBP/MAP together to get a clue. They should be very close together with normal driving.
Old Feb 4, 2015 | 09:08 AM
  #38
jhl3's Avatar
jhl3
Thank you for the info. That is what I thought but was't certain.
kjnstl
16
Aug 9, 2012 10:40 PM
Flashman
May 9, 2010 11:21 AM
sac1ses
Jun 29, 2009 04:31 PM
epeltier
Jun 6, 2006 12:55 PM
vhauger
Jun 25, 2005 04:56 AM
