Brake controller help
Old Jan 29, 2015 | 05:21 PM
tbax46's Avatar
tbax46
My brake controller doesn't always show connection and then sometimes does. However I don't power to the brakes either time. This just started after putting on new brakes. Vehicle F350, 2004, Don't know where to start looking.
Old Jan 29, 2015 | 06:37 PM
senix's Avatar
senix
Do you have an aftermarket controller? What brand?
Old Jan 29, 2015 | 06:41 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
...and what type trailer....5er or tag along.
Old Jan 29, 2015 | 06:59 PM
RV_Tech's Avatar
RV_Tech
If you pull the break-away pin, do your trailer brakes engage. Try this with the trailer unplugged from your seven pin and just try it then put the pin back in.
Steve
Old Jan 30, 2015 | 10:42 AM
tbax46's Avatar
tbax46
Steve
Yes they engage, but when the 7 pin is plugged in and breakaway pin is in there is no power to brakes.
Old Jan 30, 2015 | 02:49 PM
RV_Tech's Avatar
RV_Tech
Since you know the trailer brakes work, you can forget everything on the trailer from the junction box back. I would suggest focusing on the seven pin connection between your truck and the trailer. Do all the trailer light work when plugged into the truck?
Old Jan 30, 2015 | 03:09 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Steve, why I asked about 5er or tag along is what is he using for a ground? If a tag-along, is he using a dedicated ground or depending on the hitch ball to connect the trailer ground to the truck..... a hitch ball ground can surely cause a on again-off again connection.
Old Jan 30, 2015 | 03:33 PM
tbax46's Avatar
tbax46
Yes all lights are on
Old Jan 30, 2015 | 03:41 PM
RV_Tech's Avatar
RV_Tech
On your seven pin on your truck working the controller manually, what kind of voltage are you getting between the pin for the brakes and the ground pin?
Old Jan 30, 2015 | 03:45 PM
RV_Tech's Avatar
RV_Tech
I agree.i just haven't seen anything without s dedicated grounding pin for years. I know it is a code violation to manufacture without one, so hopefully they are few and far between.
Old Jan 30, 2015 | 06:57 PM
Big-Foot's Avatar
Big-Foot
Most truck-side trailer wiring recepticals have their ground wire connected via a crimp on connector screwed to the chassis.. More than half of all automotive eletrical problems are related to ground issues...
Old Jan 30, 2015 | 07:09 PM
RV_Tech's Avatar
RV_Tech
Easy to determine bad ground. Brake pin and ground pin voltage and if low, brake pin and chassis voltage.
Old Jan 30, 2015 | 09:47 PM
tbax46's Avatar
tbax46
Steve. Sorry took so long to answer. Had to run to town....I'm getting 11.85 at receptacle.
Old Jan 31, 2015 | 10:53 AM
RV_Tech's Avatar
RV_Tech
Now you know the controller is sending power to the pin. Your voltage is a little low, but should be enough to work the brakes.
Now since you know you have power, your next focus would be the seven pin connection between your truck and trailer. With the seven pin connected, have someone work the controller manually and take a voltage reading on the blue lead at the junction box on the trailer. The voltage there should be the same as it was at your truck.
Steve
Old Jan 31, 2015 | 10:56 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
He may have taken that reading before the glow plugs power turned itself off too, Steve.
