Just curious
Old Jan 29, 2015 | 05:13 PM
Rolszta's Avatar
Rolszta
Just curious
I come to my first of many planned upgrade/reconditioning of my 2006 F250 and the first cold snap killed my batteries. First of all they were mismatched brands, age etc. So I wanted to get the best for her and decided on optima yellow tops. I went to optima's site and they and every other parts house recommend a D35 battery for her. Why is this when the spec's call for a series 65 battery? Any input would be welcomed since I just laid out 430 bucks on this pair of D35's.
Old Jan 29, 2015 | 05:35 PM
RideDiesel88's Avatar
RideDiesel88
I spent 400 on my red tops. 870 cca. I thought yellow tops were for boats
Old Jan 29, 2015 | 05:41 PM
Rolszta's Avatar
Rolszta
Red's are starting batteries. Yellow's are deep cycle. Also better if you plan on having any stereo equipment. The blue ones are the marine's
Old Jan 29, 2015 | 06:41 PM
cheezit's Avatar
cheezit
Yellow is a mix of deep cycle and starting batteries.
Old Jan 29, 2015 | 06:51 PM
mikeysfun's Avatar
mikeysfun
Sears.com
I got a pair of these about a year ago with a coupon from sears for around $350 for the pair. Research said they were the same as Odyssey batts, come with 9 year warranty... 4 year free replacement for any reason, and 5 year pro rate after that. 930 cca each.
Reg retail on em was $250 ea... Score?
Old Jan 29, 2015 | 06:55 PM
Iaff113's Avatar
Iaff113
Originally Posted by mikeysfun
Sears.com I got a pair of these about a year ago with a coupon from sears for around $350 for the pair. Research said they were the same as Odyssey batts, come with 9 year warranty... 4 year free replacement for any reason, and 5 year pro rate after that. 930 cca each. Reg retail on em was $250 ea... Score?
That's what I run. I went with them because of the warranty and they had great reviews
Old Jan 29, 2015 | 07:54 PM
Rolszta's Avatar
Rolszta
The curiosity is still in the 35 vs the 65 class difference with the optima?
Old Jan 29, 2015 | 08:03 PM
Tedster9's Avatar
Tedster9
Group sizing has mostly to do with dimensions. So long as the ampere hour, CCA, etc meets spec, there won't be any problem. Different types of battery construction can get the same capacity in a smaller or larger case. Deep cycle batts handle discharge better than standard start batteries and less sensitive to physical shock so better for off-roading too, etc.
CASTMASTER
Mar 13, 2013 08:28 PM
cokecrazed007
Nov 5, 2008 11:34 AM
artfuldodger
Feb 11, 2008 10:46 PM
fordtruckman
2004 - 2008 F150
18
Oct 11, 2007 06:42 AM
RadarRick
Electrical Systems/Wiring
Jun 27, 2007 02:17 PM
