Need 74 carb vacuum line pic
FMC you got a collection of old 2100's too? :)
Anyway, see how that vacuum line goes from the "passenger" side of the
carburetor to the distributor's vacuum-advance unit?
My '75 Ford Shop Engine Manual shows the same as your diagram.
But some 2100's are internally plumbed to do that and some aren't.
My particular '75 360FE F150's 2100 ain't.
My 2100's passenger side port was opposite of that, its vacuum dropped
off as the throttle was opened and was highest when the throttle was
closed. You can see the port and its positon inside and see how it'd act,
(besides double checking it with a vacuum gauge). For a few years I had
it hooked up according to the dangged book and it was messed up.
My ported vacuum fitting/port is on the driver's side next the driver's side
idle mixture screw. I have/had a dozen or so 2100s and some are like mine
and most are like your diagram.
Ford huh? ;)
I wonder if that isn't where the idea that many vacuum advance units were
hooked "directly to engine vacuum by Ford" theory/myth/problem came
from?
From not looking inside the carburetor and so not knowing things have been
changed inside?
Alvin in AZ
Ford huh? ;)
from?
changed inside?
Alvin in AZ
Thanks for that addition Alvin - there were definitely some peculiarities through the years. I have seen motors from time to time that have the vacuum advance sourced from direct manifold vacuum as opposed to ported vacuum. Typically the base timing specification for these black sheep is lowered, to compensate for the fact that on these setups, the vacuum advance is operating even at idle.
Russ74
05-13-2017 07:59 AM
mudder460
17
09-23-2016 11:13 PM
darren_palms
08-19-2016 09:40 PM
alchemist1
06-27-2013 04:08 AM
