home blowers
Old 07-21-2003, 10:36 PM
Boss50's Avatar
Boss50
Boss50 is offline
home blowers
Anyone ever make a supercharger themselves?? I was trying to think of a way to do it, even if it only produced 1 or 2 lbs of boost. Any ideas? The summer is half over and I wanna end it with a bang. lol
Old 07-21-2003, 10:41 PM
Matts72's Avatar
Matts72
Matts72 is offline
home blowers
I think its a lot easier to make a home turbo. My dad got power hungry and took one off of a detroit diesel and put it on his 390 FE. Its interesting and it works too. Mostly copper pipe.
Old 07-21-2003, 11:02 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
home blowers
a homeade supercharger......i'm thinking now......
Old 07-21-2003, 11:12 PM
mustange70's Avatar
mustange70
mustange70 is offline
home blowers
how bout a electric motor(angle grinder motor would be a good one) that turns ungodful rpms, take the blower out of the heater of a ford truck then make a housing for the motor and blower, then rig up all the neccessary tubing and brakets and switches.
Or you could just rig up an idustrial shop vac some how.
Old 07-21-2003, 11:19 PM
Ryan50hrl's Avatar
Ryan50hrl
home blowers
i'd be worried about longevity of a grinder motor.....running at high rpms continuosly for six hours?
Old 07-21-2003, 11:26 PM
mustange70's Avatar
mustange70
home blowers
True, but it doesn't have to always be running though, you can turn it of till you need it, just an idea though. You just need a motor that can at high rpms for hours on end.
Old 07-22-2003, 03:14 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
home blowers
Do a little math b4 you start thinking about it...
Old 07-22-2003, 08:12 AM
Boss50's Avatar
Boss50
Boss50 is offline
home blowers
But don't electric motors like that use a different type of electricity other than the type an alternator produces?
Old 07-22-2003, 08:23 AM
Ryan50hrl's Avatar
Ryan50hrl
home blowers
sure they do, but its easy enough to convert over to ac
Old 07-22-2003, 08:29 AM
fishin1976's Avatar
fishin1976
fishin1976 is offline
home blowers
a vacuum motor/fan assembly will not make boost, the fan has to be a positive displacement design(I.E. compressor), fans are not blowers (pun intended). you could , however, get a small turbo of off a PSD, take the exhuast side off and mount a very small pully ( to make it spin fast) and make a bracket to mount it on and induction set up to the TB or carb. That would make boost.
Old 07-22-2003, 05:27 PM
Ryan50hrl's Avatar
Ryan50hrl
home blowers
the fan part itself woulnd't work, but the motor part is interesting enough....
Old 07-22-2003, 06:13 PM
mustange70's Avatar
mustange70
home blowers
The fan i'm talking about isn't like what you have in your house cooling you off on a hot summer day. Its a lot like the compressor in a turbo, what i mean is it sucks the air in through the centre of the housing then it throws it to the oustside in the same way a turbo does. I don't know how well it would produce boost through cause i believe it wouldn't produce enough psi due to the plastic design.
<get a small turbo of off a PSD, take the exhuast side off and mount a very small pully ( to make it spin fast) and make a bracket to mount it on and induction set up to the TB or carb.
I know that if you had thee compressor part it would have to spin 50,000+ rpm to make sufficient boost but for the exhaust side i wouldn't know, it would be interesting though.
Old 07-22-2003, 07:41 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
home blowers
I don't think it can be done. You'd never get the air volume required, and there would be no way to build up any pressure.
Old 07-23-2003, 12:15 AM
mustange70's Avatar
mustange70
home blowers
That leaf blower certainly could do it.
Old 07-23-2003, 10:43 AM
david.brady's Avatar
david.brady
david.brady is offline
Thumbs up home blowers
Outstanding picture! Just two more things and I've seen it all!
Quick Reply: home blowers
