Fuel pump
Old Jan 28, 2015 | 06:58 PM
pipeliner83's Avatar
pipeliner83
Fuel pump
I have a 65 ford f-100 with a 302 out of an 84 Lincoln I went back to a carb and was gonna use a mechanical fuel pump but there is no hole in the block for the rod to go through. so can anyone recommend a good electrical fuel pump that wont be pushin to much fuel for a holley 2 barrel
Old Jan 28, 2015 | 08:10 PM
Shadowrider123's Avatar
Shadowrider123
Fairly easy mod. Its best to go to a 5.0 or vintage Mustang board to ask the question. Those guys do it all the time.
1983 Mustangs ran a mechanical pump with serpentine belts. That's the front cover you will need.
Old Jan 29, 2015 | 06:38 AM
srisher's Avatar
srisher
I just took off the one on my old mustang and used a dremel to cut out the opening for the fuel pump
Old Jan 29, 2015 | 12:48 PM
ap67et10's Avatar
ap67et10
Just go get a cheap electric pump. I have a buddy that is using the mr gasket $30 electric pump from autozone on his nova wagon! He has over 15,000 miles on it now too. No regulator needed, it'll be more than enough for whatever you do. Just mount it as close to the tank as you can. It's best to run a relay to control it, but it's so small it'll probably be fine just pulling it off an ignition 12v signal. 30 min job and you are done.
Andrew
jamhh
Feb 14, 2013 02:09 PM
lbrauer
Aug 8, 2011 02:18 PM
lifted77f250
Jul 26, 2010 06:59 AM
DAI532
27
Sep 24, 2009 08:34 PM
SamD
1947 and Older Ford Trucks
Mar 21, 2004 01:18 PM
