Sagging springs
Old Jan 28, 2015 | 10:17 AM
J ballan's Avatar
J ballan
Sagging springs
So the new Ex had a 4" pro comp lift on it and the front is about 1" to 1 1/2" lower than the rear. I'm pretty sure the front springs are bagged out a bit due to the heavy 6.0l under the hood.
My question is what's the cheapest easiest way to gain around 1" of lift in the front? Looks like a add a leaf would be an option but I've had no experience installing them. Am I going down the right road with that or is there a better option? Thanks in advance.
Old Jan 28, 2015 | 10:27 AM
WE3ZS's Avatar
WE3ZS
The two cheapest ways to raise the front by an inch would be with a longer shackle on the rear of the front springs or an add-a-leaf, the shackle will be the cheaper and easier of the two. The shackle also will not affect the ride of the truck while the add-a-leaf will make it ride a little more firm.
Old Jan 28, 2015 | 10:33 AM
J ballan's Avatar
J ballan
Wouldn't longer shackles affect my caster? Not sure how that would effect my steering.
Old Jan 28, 2015 | 11:01 AM
05MilMachine's Avatar
05MilMachine
I am considering the 4 inch procomp....do you know how long it has been on there before it sank? I want to make sure I shouldn't order the 6 inch kit anticipating it to sink some.
Old Jan 28, 2015 | 11:22 AM
WE3ZS's Avatar
WE3ZS
Several members here have them and report no ill steering effects, I went with X codes with an additional leaf so I don't have any first hand experience with the shackles.
Old Jan 28, 2015 | 12:32 PM
J ballan's Avatar
J ballan
I couldn't tell you for sure but I would suspect a long time. Maybe 5 or 6 years. Seems like a decent lift. Rear is a little stiff but I'm ok with that for towing.
Old Jan 28, 2015 | 12:33 PM
J ballan's Avatar
J ballan
Cool. Thanks for the advice.
Old Jan 28, 2015 | 01:09 PM
Immortal_Ben's Avatar
Immortal_Ben
One add-a-leaf should give you about 2" of lift. That is the rule of thumb. I have no experience with longer shackles, so I cannot help you there. I DO have experience with add-a-leafs in the front, however.
If you have a plow mount, like me..... the process is pretty difficult, as the mount has to be completely removed to get to the front eye-bolt. I opted to finagle my leafs into the pack without removing everything. It was a pain, but less so than removing the whole plow mount.
If you do not have a plow mount, add-a-leafs are pretty simple and easy.
Old Jan 28, 2015 | 03:35 PM
J ballan's Avatar
J ballan
Alright so looks like I can go with one add a leaf for around 2" of lift or these shackles for around 1" of lift.
http://m.ebay.ca/itm/310463043087?_mwBanner=1
My link doesn't work. They are Zone 1" front lift shackles.
Old Jan 29, 2015 | 12:43 AM
Immortal_Ben
Well if you only want 1", go with shackles.
Old Jan 29, 2015 | 05:34 AM
WE3ZS's Avatar
WE3ZS
Longer shackles are also available if not wanting to add a leaf and are looking to retain the same ride as you currently have.
76250_4x4
Sep 18, 2013 11:45 PM
F 250 6 liter
May 21, 2011 08:55 AM
caleb6.9
Mar 7, 2010 12:22 PM
jamesbfishin
Mar 10, 2004 09:35 AM
AZ4x4f150
Feb 5, 2002 09:39 AM
