Studs vs TTY Bolts
Old Feb 2, 2015 | 03:48 PM
Asheville Engine's Avatar
Asheville Engine
Former Vendor
If it ain't broke, don't fix it but when you do, use ARP Studs and have the heads checked at a machine shop. If it does need to be done, Rusty Axlerod explained it about as well as it needs to be explained!
Old Feb 2, 2015 | 04:05 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Originally Posted by Double4LinkDiesel
The only thing I could think of someone reusing tty bolts would be they are pre stretched. I wouldn't do it, but makes you wonder if they stretch farther?
The yield point is set by the mix of metals and heat used when they make the bolts. It's pretty precise and once the bolt has "yielded" it is never as strong as before. That is to say if you do re-use them (and they don't break) they will not have as much clamping force, be as tight on install (you're using torque angle remember) and will stretch easier than they did the first time. All this is why Ford includes new bolts in the gasket kit.
About the only scenario I can think of where I'd reuse them might be if you're trying to fix the engine on the SS Minnow, and the professor can't make you a set out of coconuts.
Old Feb 2, 2015 | 06:25 PM
cheezit's Avatar
cheezit
Why on earth would I ever send heads to a machine shop to be checked. Its about as simple as it gets to do it yourself.
Old Feb 2, 2015 | 07:56 PM
william_04_x's Avatar
william_04_x
Originally Posted by mudfuel06
Are you going through with it? You're going to upset the Maxipad and goat boys over at RV.net! If you hang around this section, you'll find all the answers and tricks to dealing with the 6.0.
Those guys are still hating the 6.0l? A couple guys had problems with 03 trucks in the very beginning, and they won't let it go.
If you've opened it up, stud it. It doesn't guarantee you won't have future issues, but provides a higher level of tolerance if you experience adverse running conditions(ie: sticky turbo causing over boost/leaking injector creating excessive cylinder pressure).
Old Feb 2, 2015 | 09:47 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
B/C once you figure they're within spec only a machine shop will take .014 off the heads so you can troll FTE about your 24mpg 6.0 for a few months? Where had Monty been?
Bubba Jones
May 26, 2017 02:22 PM
Kyle Wood
Nov 7, 2016 09:10 PM
swengle
Jul 8, 2011 06:25 PM
spidermonkey
Apr 24, 2008 12:16 PM
JJDDOOGG
Dec 12, 2002 04:21 AM
