Besides that I've replaced
All brake rotors
Brake pads
Right hand rear axle seal
Brake fluid
Both tranny filters and oil
Right hand outer tie rod
Drag link off of pitman arm
Searing stabilizer shock
Fuel filters
Battery's
Head light lenses and bulbs
Tail lights
And installed a pioneer double din with ASWC-1 steering wheel controller
Great looking truck, right amount of lift and tire.
It's a pro comp 4" all spring lift but the back is like 4 1/2" and the front is 3 1/2". Think the old 6.0l has taken it's toll on the front springs. Tires are 35"
I hear ya bro! Hey did you have to do much modification to get that beast in the dash?
Nope. Pretty straight forward as far as physically installing the deck. Had to trim the top and bottom of the opening to get it in there. The wiring was a bit of a challenge.
