carburerator issues
Old Jan 25, 2015 | 04:08 PM
Jacksoncummins79's Avatar
Jacksoncummins79
carburerator issues
I have a '79 Ford 4x4 F250 with a 400m. I just put a new remanufactured UREMCO carb. I put everything on as should, and put the choke cover on as it is in the directions but the choke is on 24/7 no matter what I adjusted the choke cover and now the choke is off 24/7 but dies since its not getting enough fuel. need advice on what to do! thanks Sam.
Old Jan 25, 2015 | 04:18 PM
Tedster9's Avatar
Tedster9
This is for Holley but is a good overview of general carb setup. Start with fuel delivery. The fuel pump HAS to provide the right amount of both volume and pressure at all times. Make sure linkage is setup correct and set idle and idle mixture to mechanical zero and start from there?
http://www.junkyardgenius.com/holley/tune01.html
columbia1spring
Feb 12, 2018 03:45 PM
DrunkFord
Feb 18, 2011 01:02 AM
twinzilla
Feb 7, 2010 09:40 PM
pwarren68-2008
Sep 15, 2009 06:11 PM
ford390gashog
Feb 8, 2005 05:43 PM
