1995 351W Build Help Needed
Old Jan 24, 2015 | 09:30 PM
4020FarmBoy's Avatar
4020FarmBoy
Need to rebuild the 351W in my '95 F250. A stroker is not an option but I am going for torque. A buddy is going to put it together for me but I need to get the parts together. I have been lurking for a while trying to figure out what I need but now that I am ready to build it I have some more specific questions. I already have GT40 heads. I was planning to order
PP Typhoon Lower
Edelbrock Performer Truck Upper (plan to stay in stock rpm range)
Pacesetter LT headers
Should I keep the stock rocker ratio or change to 1.7?
What cam should I run? I assume its a roller cam block but have not looked
Recommended pistons & CR to stay on pump gas?
Is their anything else I may be overlooking?
Thanks for any help.
Old Jan 25, 2015 | 10:16 AM
Conanski's Avatar
Conanski
Add 1.7 rockers with the stock cam or use the Comp 35-512-8 with the stock rockers.
9.5:1 is about the max CR you can run, no need for anything beyond cast or hyper pistons on a low rpm truck motor.
Old Jan 25, 2015 | 02:52 PM
gman97005's Avatar
gman97005
Originally Posted by 4020FarmBoy
Need to rebuild the 351W for torque, already have GT40 heads.
PP Typhoon Lower
Should I keep the stock rocker ratio or change to 1.7?Recommended pistons & CR to stay on pump gas?
Even with GT40's the stock intake flows plenty of air for a truck motor but you could always have the intake Extrude Honed and it will flow even better.
Headers are great, be sure to add crossover (H-pipe) directly behind the collectors.
Changing the cam will require recalibrating the MAF Sensor, are you prepared for that expense ?
1.7's are viable alternative that will provide small increase in both torque and horsepower.
Combustion chamber design, total advance and quench has more to do with minimum octane level than the compression ratio.
Old Jan 25, 2015 | 05:14 PM
Conanski's Avatar
Conanski
No.. the 5.8 version does not.
No it won't, the MAF calibration file exists inside the PCM and the cam has no impact on it.
Agreed but.. the OP cannot easily change the chamber shape or quench of the heads in use so anything beyond 9.5:1 static CR and the stock ignition advance curve will result in detonation problems given the weight of the vehicle in question.
Old Jan 25, 2015 | 05:23 PM
gman97005's Avatar
gman97005
Didn't realize stock intake was that restrictive, even for the stock engine or just with GT40's ?
For some reason i was thinking there was a change in the intake hose leading to the MAF, which would require the MAF to be recalibrated.
You are correct, he is limited on options and has to stay under or at 9.5 static to be pump gas friendly.
I'm typical Virgo and over-think everything
Old Jan 25, 2015 | 08:09 PM
Conanski's Avatar
Conanski
Maybe you were thinking of the 5.0 truck intake.. believe it or not the 5.8 version is a fair bit smaller of all things.. what was Ford thinking? But yeah on this displacement the stock intake(and heads) are equally restrictive period and the motor gains both HP and with upgrades to those parts.
Old Jan 25, 2015 | 08:17 PM
gman97005's Avatar
gman97005
well fudge, that is all kinds of messed up, increase displacement and reduce intake runner volume, another better idea by Ford i guess but i am seriously considering doing intake swap now, does the stock 5.8 throttle body fit the aftermarket intake ?
Old Jan 25, 2015 | 09:53 PM
Conanski's Avatar
Conanski
The only aftermarket intake that the stock TB will fit is the Edelbrock EFI Truck, it uses the performer lower with a super long runner upper portion. The ports in this thing are larger and flow better but the runners are tuned even lower than the factory intake so it's really only good if you're looking to maximize low rpm torque from a stockish motor, if you want more HP too it's totally wrong.
Old Jan 30, 2015 | 04:45 PM
jimbbski's Avatar
jimbbski
I'm just guessing here but I bet Ford figured that since the only vehicles the 5.8L were going into come 1988 were TRUCKS they decided to tune it for low end torque only. The only two models that got a performance 5.8L was the 1995 SVT Mustang Cobra R and the Ford Lighting PU. Both got the GT40 intake. This is one reason that the truck 5.8L responds to even simple mods such as headers, a mild cam, better heads, etc. But to get any real upper RPM power is to change the stock intake.
majic
19
Feb 3, 2020 05:31 PM
PRIMERED79 SHORT BED
76
Aug 22, 2019 09:29 PM
Rusty_S
Jul 22, 2015 01:40 PM
grumpy44
Jul 25, 2004 09:21 PM
minnesota4x4
Mar 25, 2003 01:34 PM
