crankcase vent
Old Jan 24, 2015 | 09:29 PM
saauvenshine's Avatar
saauvenshine
Question crankcase vent
Finally got my 54 truck with 239 ohv running tonight and after I let it run for a few minutes I noticed oil underneath. I had forgot to put crankcase canister back on and was wondering if its normal to have oil coming out. Even if canister was on is it supposed to have oil going to or in it.
Old Jan 25, 2015 | 07:11 AM
raytasch's Avatar
raytasch
Believe Nothing
If you are talking about the oil filter canister, yes, the oil is under pressure in it when the engine is running. If you are talking about the filler cap, no, the oil should not come out.
Old Jan 25, 2015 | 07:28 AM
pintoplumber's Avatar
pintoplumber
If you're talking about the road draft canister on the side, yes it will leak. There is provision in it to drain oil back into the block. Dennis
Old Mar 9, 2015 | 06:30 PM
greenmachine55's Avatar
greenmachine55
Don't do what I did....I thought I had a lot of blow by from my 239, but really it was just my draft tube leaking from the inner side closest to the block. And...almost all draft tubes leak alittle especially after all these years and them getting banged around.
slabhunter
Sep 17, 2018 07:19 PM
maevans
Feb 21, 2014 06:01 AM
jason867
1983 - 2012 Ranger & B-Series
15
Mar 7, 2012 08:36 PM
Cobratodd
Apr 6, 2006 06:12 AM
laredo7mma
Sep 30, 2005 12:32 PM
