upper control arm cam bolts 1999 F150
On the upper control arm the replacement part is made by Moog. I got their cam bolt kit and the picture seems to show the washers on both ends touching the frame mounts instead of the can adjustable discs. Is this correct? In other words is is bolt head, disc, washer, frame mount, inside of frame mounts, washer, disc, nut? It seems to me the washers should be next to the bolt head and nut instead of the discs....??? First time doing anything with suspension, so I'm wanting to get it right before taking in for alignment.
