break line replacement help
Old Jan 24, 2015 | 03:51 PM
4CFarms's Avatar
4CFarms
So I blew a brake line today and i need some help with trying to fix it... its the line that runs from the rabs to the rear axle where it junctions off. it is a steel line so i am assuming that it is finally rusted out. Do i need to drop the front tank to get in there? Also, is there anything i need to keep in mind? What fittings should i use and how does the fitting unscrew from the RABS? All i know is that i need a double flare tool and need to bleed brakes when im done.
Do i need to take the wheels off to bleed the brakes??
Do i need a tool to bend the metal brake pipes??
Any and all help would be greatly appreciated...
Old Jan 24, 2015 | 04:15 PM
BuckHammer's Avatar
BuckHammer
These trucks are getting old. If the lines are all original, I would replace them all at the same time right now. Otherwise, you'll be fighting them one at a time for years. Trust me. It happened to me. I got a pre-bent set. I'll try to find a link here in a minute.
Edit: It was a seller named Inline Tube on eBay. I got stainless prebent lines. Replaced them all with only vise-grips and combo wrenches. Still haven't bled them. What can I say? I'm a slacker. Haha
Old Jan 24, 2015 | 04:25 PM
4CFarms's Avatar
4CFarms
I had the lines mounted on the axle all replaced but I need to replace the ones in the frame rail. But isn't there only one line that runs from the RABS to the axle?
Old Jan 24, 2015 | 04:29 PM
BuckHammer's Avatar
BuckHammer
Yeah. I would replace every hard line that was installed at the factory at this point if I were you. It's a long line, I guess depending on your wheelbase, as you can see by looking at it. You could probably replace the segment from the RABS to the leak or from the leak to the little frame fitting where it connects to the rubber hose, whichever is shorter or makes more sense. Just double flare the ends, and connect them with a union.
Old Jan 24, 2015 | 04:41 PM
4CFarms's Avatar
4CFarms
So u think it'd be worth it to drop the tank bec I don't see how I can get in there and work on it without dropping it...
Old Jan 24, 2015 | 05:53 PM
MI02SVT's Avatar
MI02SVT
If you don't want to drop the tank just run the new line in through it and frame
Old Jan 24, 2015 | 07:07 PM
Diesel_Brad's Avatar
Diesel_Brad
You can fish it behind the tank no problem, that is the least of your concerns.
Flaring the line will be your problem
Old Jan 25, 2015 | 02:37 AM
BuckHammer's Avatar
BuckHammer
Yeah, you shouldn't have any issues with the tank.
Old Apr 20, 2016 | 06:42 PM
gotama's Avatar
gotama
hey any of you know the length of the line from the junction underneath the master cylinder that goes over to the right front caliper?..im gonna crawl underneath tom and look, have to get a buddy to pick one up for me in the morn so i can get going and stopping again..i know im reviving an old thread..thanks if you can help me save some time and my clean clothes
hharris8
195
Dec 16, 2016 09:32 AM
Walkswithdogs
Jul 8, 2013 12:56 PM
Plain Jane
Sep 30, 2011 07:22 PM
blackenedbodom
Nov 24, 2010 12:04 AM
SAlexander
Aug 23, 2004 02:29 PM
