the ground for the cluster I believe is located under the hood, passenger side cowl. Can't miss it next to the hinge lift for the hood.
The other ground is located near the battery, another located right of radiator, driver side core support, next is by the EEC diadnostic connector, another one located down under the frame , core support to frame, passenger side, another one just at passenger door under truck of the door.
Thank you for all the help!
I think i found the issue.. I just went out and pulled the headlight switch and here's what I found.
