Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
escape headache
Old Jan 23, 2015 | 06:44 PM
itswrongway's Avatar
itswrongway
escape headache
I'm still having trouble getting my escape to run right . because of the cold weather in northeast pa I haven't been able to work on it much . one question . will low fuel pressure cause hard start and and backfire through the intake with slow rev up and some hesitation ??
Old Jan 24, 2015 | 06:52 AM
Dan Robertson's Avatar
Dan Robertson
I'm not sure about the back fire but low fuel pressure will cause hard starts and a rough idle for a few seconds. My 98 Ford Ranger does that (w/o the back fire) unless I cycle the key several times before starting it. It has about 15 pounds on the first cycle, and it increases about 10 pis on each cycle to about 45 on the 4th cycle. As soon as the engine starts, the fuel pressure jumps to 60 psi and holds there. I am told that it is a weak fuel pressure regulator but I am not going to fix it because I am also told that it is part of the pump and I don't want to take it out this time of year. (northern Maine) The outside temp also effects it. It starts good in the warmer months.
Banjo250
1997 - 2003 F150
18
Jul 2, 2019 04:29 PM
rcw3023
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 29, 2014 06:55 PM
bronco cam
1978 - 1996 Big Bronco
29
Jun 13, 2011 02:59 AM
Reticle
Modular V10 (6.8l)
Oct 28, 2010 11:06 AM
baldman
1997 - 2003 F150
Mar 23, 2007 01:44 AM
