Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Head Gasket
Old Jan 20, 2015 | 05:51 PM
sangster88's Avatar
sangster88
Head Gasket
Hello all! Im new to the site so thanks for havin me. So heres the question and any help would be great, I found a ford escape in great condition other than the fact the head gasket is blown. The truck has high mileage but everything seems to be mint. Im going to have another look at it in a couple days and just wondering what i should be looking for to see how serious it is. Im going to tackle the head gasket job myself so is there anything i can look for now to see if its just the gasket that needs to be replaced or if its going to be more in depth ie. pistons, rings, block, crank, cylinders... The truck is a 2001 escape 3.0l xlt 4wd
Old Jan 20, 2015 | 08:54 PM
scott91370's Avatar
scott91370
If the oil is milky you may be in for more work than just a gasket. The more/longer the water is in there the more damage it will cause.
Old Jan 20, 2015 | 08:56 PM
JWC 3's Avatar
JWC 3
That is no fun job with the engine in .Heck not fun with it out !
Old Jan 20, 2015 | 09:02 PM
sangster88's Avatar
sangster88
yeah i didnt think so but im getting it for $600 so the headache would be worth it if its just the gasket... just not sure if when i get it back together the trannys gunna be slippin or somethin... so just seeing if theres ways of checking things to put the gamble more in my favor or just run...
Old Jan 20, 2015 | 09:29 PM
JWC 3's Avatar
JWC 3
If you pull the heads , they need to go to a machine shop to be checked . After all is said and done , a used engine may be a better choice . Who knows what you will find when you get into it . And , what caused the failure , water pump , radiator , heater core blew out and dumped all the coolant , fan issues , wiring to the fans , control issues with the fans .......
Old Jan 20, 2015 | 09:40 PM
sangster88's Avatar
sangster88
yeah well thats worse case scenario... just looking for some info on how to detect these things...
Old Jan 21, 2015 | 06:00 PM
sangster88's Avatar
sangster88
any other ideas or opinions?
Old Jan 26, 2015 | 03:18 PM
Viktor Sigurgeirsson's Avatar
Just find another engine and swap it. Thats the only way to go, and by far cheaper than to rebuild the engine.
skidoorulz
Mar 31, 2015 03:29 PM
mr.fordneck
Jan 7, 2011 11:07 AM
LedheadELH
Jan 26, 2007 08:15 PM
D9351
Feb 10, 2003 05:51 AM
