Could use a hand
Old Jan 22, 2015 | 02:58 PM
big_red1402's Avatar
big_red1402
Question Could use a hand
Its been a while since I've been on here, but I'm having an issue you may be able to help me with. I got an 88 f150 rcsb 4x4 4 speed 302, a lot of miles, not exactly sure how many due to the old school odometers. Anyway, a while back out of nowhere the return fuel started flowing into the front tank, which was removed as part of the initial diagnoses because it was rusted away anyway. The switch valve on the frame rail was also removed at roughly the same time to eliminate this problem and force that fuel into the rear tank. About that time the fuel pressure regulator went bad. IT blew 3 of them there, and then finally one held for a while. It recently blew again and I have put 3 on and they don't even last more than roughly 10 miles before going out again. I've read several older posts with similar issues, but none that sound like mine. Any help is greatly appreciated.
Old Jan 22, 2015 | 07:34 PM
Eddiec1564's Avatar
Eddiec1564
Check and make sure the fuel return line is not plugged up. Verify the fuel pressure is correct(around 40psi).
What did you use to bypass the fuel selector valve when it was removed?
Old Jan 23, 2015 | 05:08 PM
big_red1402
When we removed the valve we replaced it with regular steel fuel line, no kinks, I took an air compressor with the last one and blew the return line out from the lines back, but it still blew the regulator. I'm not sure if the compressor actually got through the line, due to my blower nozzle not being the best. I'm considering just replacing the lines just to help diagnose, but no local shops have the line. Might try using a different nozzle to clear the lines tomorrow
Old Jan 23, 2015 | 07:40 PM
Eddiec1564's Avatar
Eddiec1564
If you can, remove the fuel pressure reg and try blowing through the return line. There should be hardly any back pressure on the return line.
Old Jan 24, 2015 | 08:48 AM
'89F2urd's Avatar
'89F2urd
are you sure you have your lines connected correctly after deleting the selector valve?
prior to removing the selector, you had a bad check valve in your front tank. . .replacing that would have likely solved your problem.
now it seems you have new issues introduced to the mix...
Old Jan 24, 2015 | 09:04 AM
rla2005's Avatar
rla2005
A 1988 truck does not have check valves in each tank like the 1990 and newer trucks. The dual function reservoir provides that function. That device is also referred to as "selector valve".
Old Jan 24, 2015 | 01:39 PM
babarche's Avatar
babarche
What brand of parts are failing? Motorcraft is best IMO. Definitely need to confirm pressure when running and diagnose why if it is not correct.
doc7f
1997 - 2003 F150
Oct 23, 2023 06:54 PM
meck1
1983 - 2012 Ranger & B-Series
Jun 19, 2018 03:18 PM
Stephenn95
Sep 15, 2015 07:36 PM
jmcotski
Nov 19, 2011 09:03 AM
57Fitzjohn
Apr 17, 2008 03:03 PM
