HELP: Which is supply and which is return? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Reload this Page >
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-17-2018, 02:24 PM
meck1
meck1 is offline
meck1 is starting off with a positive reputation.
On a '97 3.0, which line at the fuel injector rail is the supply line and which is the return? The engine is not in a vehicle, so i can't trace the lines back to the filter or tank. I'm thinking that the line coming off nearest the fuel pressure regulator is the return line, but is this correct? Thanks.
Old 06-17-2018, 05:53 PM
mfp4073's Avatar
mfp4073
mfp4073 is offline
mfp4073 is gaining momentum as a positive member of FTE.mfp4073 is gaining momentum as a positive member of FTE.
if its the same as my 99 and 04 the fuel line comes in from the drivers side and hooks the the fuel rail on the passenger side. Its to the passenger side of the intake.
Old 06-17-2018, 05:54 PM
spooktn
spooktn is offline
spooktn is gaining momentum as a positive member of FTE.
in line should have a fuel pressure regulator or schraider valve on it ,,, return doesnot have anything that i know of
Old 06-18-2018, 04:36 AM
meck1
meck1 is offline
Thanks for the replies, but I believe our trucks are different. Mine has two fuel lines, one from the tank and one to return excess fuel to the tank. In '98, they went to a single line, supply only, no return.
I have two lines, one goes to the fuel rail that runs under the intake plenum between the two engine banks. The other line comes off the fuel rail that is on the passenger side of the engine where the fuel pressure regulator is located.. Can anyone tell me with certainty which is
Old 06-18-2018, 09:31 PM
ranger pat's Avatar
ranger pat
ranger pat is offline
ranger pat has a very good reputation on FTE.ranger pat has a very good reputation on FTE.ranger pat has a very good reputation on FTE.
I seem to remember they are different diameters. The large one is supply and the smaller one is the return.
Old 06-19-2018, 03:18 PM
meck1
meck1 is offline
They are two different sizes, as you said, and the larger one is the one I was guessing was the supply. That is what I will go with. Thanks for your reply.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
