cruise control crapped
Old Jan 22, 2015 | 02:02 PM
cedman's Avatar
cedman
Cruise just stopped working. The fuses all check out ok. What would be the next simplest thing that I could check before turning the problem over to a mechanic?
Thanks, CedricR.
Old Jan 22, 2015 | 02:10 PM
BigAlsPSD's Avatar
BigAlsPSD
Maybe the brake pressure switch if it's an auto...clock spring contact condition in the steering column would be another possibility.
Since the cruise is controlled by the PCM, there is not much to this system.
Old Jan 22, 2015 | 02:48 PM
mototrig's Avatar
mototrig
When I bought me truck my cruise control didn't work. I replaced the clock spring and fixed the issue.
With the key on check for good power and ground for the CC wiring in the steering column with a meter. If you have good power and ground there, check the same in the steering wheel behind the air bag. IIRC there are 4 screws on the back side of the steering wheel holding the air bag to the wheel.
Disconnect the batteries and remove the airbag completely. Reconnect the batt's and check for good power and ground and CC switch function. No power or bad ground at the steering wheel are likely signs of a bad clock spring.
Before doing any of this make sure none of your brake lights are burnt out or have corroded wire connectors. This includes the cab rear brake light. And make sure the problem is not the brake switch on the master cylinder. Have a drink and good luck
Old Jan 22, 2015 | 03:44 PM
whitetmw's Avatar
whitetmw
Do you have access to a Scanner? Preferably with a Ford Key/Bundle?
Old Jan 22, 2015 | 04:07 PM
Nick 99's Avatar
Nick 99
Check to make sure the switch on the parking brake is not intermitant, that's what happened to my cruise system. Readjusted the paking brake mechanism to give the switch a more positive action and trouble went away along with brake lamp on dash.
Old Jan 23, 2015 | 08:25 AM
Tugly's Avatar
Tugly
This might help: [LINK]
Old Jan 25, 2015 | 07:12 PM
thomabb's Avatar
thomabb
Did you check the fuse in the wiring harness that comes off the brake master cylinder? This fused wire is the cruise control recall fix. If the pressure switch goes, the fuse pops.
Old Apr 10, 2015 | 12:27 PM
cedman's Avatar
cedman
FINALLY! I have gotten around to checking this out. (It's about time people stop getting hurt and/or dying around here!)
Tried Tugly's link. I got nuthin'. No light on dash or anywhere else. I'll check and see if this truck is subject to the recall. Then try the brake pressure switch next.
Thanks guys.
CedricR.
Old Apr 10, 2015 | 12:42 PM
cedman's Avatar
cedman
Well... my truck is NOT subject to the cruise control recall but is subject to a new fuel tank locator bracket.
Old Apr 14, 2015 | 11:39 AM
Fat Diesel's Avatar
Fat Diesel
Does your horn work? On my e99 the horn and cruise use the same relay.
Old Apr 14, 2015 | 04:06 PM
cedman's Avatar
cedman
yeah horn works. mu guess is the clock spring as it's probably the most expensive part!
Old Apr 14, 2015 | 11:33 PM
AllBeefFranks's Avatar
AllBeefFranks
is your truck tuned or stock? I've got an SCT tuner on my truck and occasionally i've had this cause issues when i download the tunes.
Old Apr 15, 2015 | 08:22 AM
cedman's Avatar
cedman
Pretty much stock as I am pretty much poor!!
Old Apr 15, 2015 | 09:12 PM
sgarder's Avatar
sgarder
Without a scan tool, First check the fuses (you have already). If you have a ohmmeter check sensor on the brake master cylinder for continuity. If no ohmmeter (multimeter) unhook the wire harness from the sensor and jump the terminals of the wire harness, and insulate so the jumper can not short out. Test drive. BE CAREFUL the cruise may not shut off with pushing of the brake pedal use the off button on the steering wheel. This will test if the sensor on master cylinder is good or not. According to my local independent mechanic, and good friend. nine out of ten times the sensor on the master brake cylinder has been the issue for him. If this does not work,,, time to dig deeper.
Old Apr 29, 2015 | 08:07 AM
cedman's Avatar
cedman
The brake switch checks out ok as does the wiring harness connected to it. I removed the airbag and i am replacing the CC switch assembly as I broke it getting it out... don't know if it was actually broken before gorilla fingers got hold of it!
Is the air bag assembly and the clock spring all the same part?
