Ignition Cylinder
Old Jan 22, 2015 | 10:13 AM
dnkensinger's Avatar
dnkensinger
Ignition Cylinder
I'm just wondering what other parts (if any) are involved in a correctly functioning ignition lock cylinder. Right now, the cylinder isn't turning and operating properly, as in when I go to start the truck, it's difficult to turn and it doesn't spring back from the START to RUN position, I have to manually turn it back.
I don't know if this is something I have to tear apart the column to fix or what?
Thanks.
Old Jan 22, 2015 | 11:41 AM
trevisM's Avatar
trevisM
Old Jan 22, 2015 | 02:27 PM
Franklin2's Avatar
Franklin2
Replace the ignition switch on top of the column underneath the dash. And flood the area where you put the key with wd40. Hold a rag in your lap to catch the run-off and keep working it back and forth.
Old Jan 22, 2015 | 04:05 PM
dnkensinger
Thanks for the links! How did you find a past post that quickly? Is there a way to search keywords for old posts?
Old Jan 22, 2015 | 06:21 PM
trevisM's Avatar
trevisM
Those were in;
Read First: The '80-'86 Sticky - Tech Tips & Tricks (Multi-page thread 1 2)
horsepuller
and;
'80-'86 HOWTO's
at the top of this sub forum, happens I was blundering around there recently and remembered seeing them.
There is a site search, but Google plus the website works for me some times.
kjhansen
23
Jun 13, 2019 07:56 PM
GN1220
Feb 21, 2017 07:16 PM
forddriver78
Jul 13, 2015 01:51 PM
Mindwrack
Jul 19, 2013 08:33 PM
Donald Becknel
Jan 12, 2010 08:05 AM
