Bronco II Ford Bronco II
Bronco II flywheels--keep breaking
Old Jul 21, 2003 | 05:32 PM
Jimbo Gray's Avatar
Jimbo Gray
Question Bronco II flywheels--keep breaking
I have a 87Bronco II
The problem is Flywheels ,I've replaced 2 in a year .
they keep breaking where they bolt to the crank.
Yes both the thing will work for a very short while then BANG no go...
I knowthis cant be right,I'm a wrench and can repare a truck...LOL no but is there something wrong with this that you might know That I don't ?
Let me hear from you .
Old Aug 18, 2003 | 01:04 AM
Scooter29's Avatar
Scooter29
Hey Jim, I was just checking back to see if I could assist with someone left behind. Maybe it'll help.
You need to have the flywheel weigh the same as the harmonic balancer on the front. The weight should be stamped on it. If not, you'll have to remove it and have it weighed. They are usually 50oz. Your machine shop can mill down the flywheel, or add weights if needed, and then balance it. You shouldn't have any more problems from then on.
Talk with you later....
bronocIInoob
Escape & Escape Hybrid
19
Feb 28, 2006 06:57 PM
t-nip
Bronco II
Sep 22, 2005 05:11 PM
02Bora1.8t
Bronco II
Apr 15, 2005 03:54 PM
poffutt
1978 - 1996 Big Bronco
Jan 21, 2005 08:09 AM
imxscarredxtoo
4 Cylinder Engines
Nov 27, 2004 05:58 PM
